Wood Screws - Withdrawal Force
Allowable withdrawal load or force of a common wood screw into side grain perpendicular to the fibers of seasoned dry wood can be expressed as
F = 2850 SG 2 D                   (1)
F = allowable withdrawal load or force - lb per inch of penetration (lb/in)
SG = specific gravity of oven dry wood
D = diameter of screw (in)
Note the difference between allowable load and failure load. Allowable load includes design and safety factors and ranges typically between 2 and 10. Depending on the case allowable load is normally 10 - 50% of the failure load.
Example - Screw Allowable Withdrawal Load
The specific gravity of Canadian Spruce is 0.45 . The diameter of no. 10 screw is 0.190 inches . The withdrawal force per inch of penetration can be estimated as
F = 2850 (0.45) 2 (0.190 in)
= 109 lb per inch of penetration
Screw Withdrawal Force Calculator
Imperial Units
Metric Units
Fasteners
Miscellaneous
Drill Bits - Conversion Chart
Convert between drill bit dimensions - gauge numbers, inches and mm.
Glue-Laminated Timber - Dimensions
Common sizing of glue-laminated timber.
Hardwood and Softwood Species
Species of hardwood vs. softwood.
Hardwood and Softwoods - Recommended Drill Bit Speeds
Hardwood and softwood drill speed chart.
Hardwood Lumber - Dimensions
Sizing of hardwood lumber.
Machine Stress Rated (MSR) and Machine Evaluated (MEL) Lumber
Grading of lumber in North America
Metric Threads - Clearance Holes and Tapping Drill Sizes
Recommended clearance holes and drill tap sizes.
Nails and Spikes - Withdrawal Force
Allowable withdrawal load for nail and spikes.
Softwood and Hardwood - Structural Strength Classes
Strength classes, bending stress and mean density of hardwood and softwood
UNC and UNF - Unified Inch Screw Threads
US Machine Screws - Dimensions
Machine screw diameters.
US Wood Screws - Nominal Sizes
Wood screws - nominal sizes vs. diameters.
US Wood Screws - Pilot Holes
Hard wood and soft wood pilot holes, shank clearance holes and countersink diameters.
Wood Beams - Strength of Material
Wood Headers - Max. Supported Weight
Wood Species - Densities
Wood, Panel and Structural Timber Products - Mechanical Properties
Density, fibre stress, compressive strength and modulus of elasticity of clear wood, panel and structural timber products.
