Wood, Panel and Structural Timber Products - Mechanical Properties
Clear Wood
Wood Products - Mechanical Properties
WoodDensity
ρ -
(kg/m3)
Fibre Stress at Elastic Limit
- σy -
(MPa)
Modulus of Elasticity
- E -
(GPa)
Compressive Strength parallel to Grain
- σ -
(MPa)
Shear Strength parallel to grain
- τ -
(MPa)
Alder, red 410 68 9.5 40.1 7.4
Ash - Black, Blue, Green, Oregon, White 490 - 600 87 - 103 9.4 - 12 41.2 - 51.1 10.8 - 14
Aspen - Bigtooth, Quaking 390 63 9.9 36.5 7.4
Baldcypress 460 73 9.9 43.9 6.9
Baswood, American 370 60 10.1 32.6 6.9
Beech, American 640 103 11.9 50.3 13.9
Birch - Paper, Sweet, Yellow 550 - 620 85 - 114 11 - 15 39.2 - 58.9 8.3 - 15.4
Butternut 380 56 8.1 36.2 8.1
Cedar - Atlantic White, Eastern Red, Incence, Northern White, Port-Orford, Western Red, Yellow 310 - 470 45 - 88 5.5 - 11.7 27.3 - 43.5 5.5 - 9.4
Cherry, black 500 85 10.3 49 11.7
Chestnut, American 430 59 8.5 36.7 7.4
Cottonwood - Balam Poplar, Black, Eastern 310 - 400 27 - 59 7.6 - 9.4 27.7 - 33.9 5.4 - 7.2
Douglas-fir - Coast, Inerior West, Interior North, Interior South 460 - 500 82 - 90 10.3 - 13.4 43.1 - 51.2 7.8 - 10.4
Elm, English 560 40 - 54 11.8 17 - 32 8 - 11.3
Elm, Dutch 560 42 - 60 7.7 18 - 32 7.2 - 10
Fir 320 - 430 61.4 - 75.8 8.9 - 11.9 33.5 - 44.2 6.2 - 8.4
Hackberry 530 76 8.2 37.5 11
Hemlock - Eastern, Mountain, Western 400 - 450 61 - 79 8.3 - 11.3 37.3 - 49 7.3 - 10.6
Hickory, pecan - Bitternut, Nutmeg, Pecan, Water 600 - 660 94 - 123 11.7 - 13.9 47.6 - 62.3 14.3
Hickory, true - Mockernut, Pignut, Shagbark, Shellbark 690 - 720 125 - 139 14.9 - 15.6 55.2 - 63.5 12 - 16.8
Honeylocust 101 11.2 51.7 15.5
Larch, Western 520 90 12.9 52.5
Locust, black 690 134 14.1 70.2 17.1
Magnolia - Cucumbertree, Southern 480 - 500 77 - 85 9.7 - 12.5 37.6 - 43.5 9.2 - 10.5
Mahogany 545 60 8.7 45 6.0
Maple - Bigleaf, Black, Red, Silver, Sugar 480 - 630 61 - 109 7.9 - 12.6 36 - 54 11.9 - 16.1
Oak, red - Black, Cherrybark, laurel, Northern Red, Pin, Scarlet, Southern Red, Water, Willow 590 - 690 75 - 125 10.3 - 13.1 42 - 60.3 9.6 - 14.3
Oak, white - Bur, Chestnut, Live, Overcup, Post, Swamp Chestnut, Swamp White, White 640 - 880 71 - 127 7.1 - 13.7 41.8 - 61.4 10.3 - 13.8
Pine - Eastern White, Jack, Loblolly, Lodgepole, Longleaf, Pitch 350 - 590 59 - 100 8.5 - 13.7 33.1 - 49.2 6.1 - 10.4
Poplar, Yellow 420 70 10.9 38.2 8.2
Sassafras 460 62 7.7 32.8 8.5
Spruce - Black, Engelmann, Red, Sitka, White, Norway 350 - 430 63 - 79 7.9 - 11 37 - 44 6.8 - 9.2
Sweetgum 520 86 11.3 43.6 11
Sycamore, American 490 69 9.8 37.1 10.1
Tupelo - Black, Water 500 66 8.3 - 8.7 38.1 - 40.8 9.2 - 11
Walnut, black 550 101 11.6 52.3 9.4
Willow, black 390 54 7 28.3 8.6
Download and print Tension Unit Converter Chart
Panel Products
Panel Products - Mechanical Properties
PanelDensity
ρ -
(kg/m3)
- σy -
(MPa)
- E -
(GPa)
Hardboard 900 - 1000 31 - 56 3.1 - 5.5
MDF - Medium Density Fiberboard 700 - 900 36 3.6
Particleboard 600 - 800 15 - 24 2.8 - 4.1
OSB - Oriented Strandboard 500 - 800 22 - 35 4.4 - 6.3
Plywood 400 - 600 34 - 43 7 - 8.6
Structural TimberDensity
ρ -
(kg/m3)
- σy -
(MPa)
- E -
(GPa)
Glued-laminated Timber 400 - 600 29 - 63 9 - 14.5
Laminated Veneer Lumber 400 - 700 34 - 86 9 - 19
Beams and Columns
Drill Bits - Conversion Chart
Convert between drill bit dimensions - gauge numbers, inches and mm.
Hardwood and Softwood Species
Species of hardwood vs. softwood.
Lumber - Weights
Machine Stress Rated (MSR) and Machine Evaluated (MEL) Lumber
Grading of lumber in North America
Softwood and Hardwood - Structural Strength Classes
Strength classes, bending stress and mean density of hardwood and softwood
Structural Lumber - Section Sizes
Basic size, area, moments of inertia and section modulus for timber - metric units.
Structural Lumber - Properties
Wood - Compressive Strength vs. Moisture Content
Red Spruce, Longleaf Pine and Douglas Fir - moisture content and their compressive strength.
Wood Beams - Strength of Material
Wood Columns - Safe Loads
Safe loads for wood columns.
Wood Hardness
Soft and hardwood - the Janka Hardness scale.
Wood Headers - Max. Supported Weight
Wood Screws - Withdrawal Force
Allowable withdrawal load force.
Wood Species - Densities
Young's Modulus, Tensile Strength and Yield Strength Values for some Materials
Young's Modulus (or Tensile Modulus alt. Modulus of Elasticity) and Ultimate Tensile Strength and Yield Strength for materials like steel, glass, wood and many more.
