Stress
Stress is the ratio of applied force F to a cross section area - defined as "force per unit area".
- tensile stress - stress that tends to stretch or lengthen the material - acts normal to the stressed area
- compressive stress - stress that tends to compress or shorten the material - acts normal to the stressed area
- shearing stress - stress that tends to shear the material - acts in plane to the stressed area at right-angles to compressive or tensile stress
Tensile or Compressive Stress - Normal Stress
Tensile or compressive stress normal to the plane is usually denoted "normal stress" or "direct stress" and can be expressed as
σ = Fn / A (1)
σ = normal stress (Pa (N/m2), psi (lbf/in2))
Fn = normal force acting perpendicular to the area (N, lbf)
A = area (m2, in2)
- a kip is an imperial unit of force - it equals 1000 lbf (pounds-force)
- 1 kip = 4448.2216 Newtons (N) = 4.4482216 kilo Newtons (kN)
A normal force acts perpendicular to area and is developed whenever external loads tends to push or pull the two segments of a body.
Example - Tensile Force acting on a Rod
A force of 10 kN is acting on a circular rod with diameter 10 mm. The stress in the rod can be calculated as
σ = (10×103 N) / (π ((10×10-3 m) / 2)2)
= 127388535 N/m2
= 127 MPa
Example - Force acting on a Douglas Fir Square Post
A compressive load of 30000 lb is acting on short square 6 x 6 in post of Douglas fir. The dressed size of the post is 5.5 x 5.5 in and the compressive stress can be calculated as
σ = (30000 lb) / ((5.5 in) (5.5 in))
= 991 lb/in2 (psi)
Shear Stress
Stress parallel to a plane is usually denoted as "shear stress" and can be expressed as
τ = Fp / A (2)
τ = shear stress (Pa (N/m2), psi (lbf/in2))
Fp = shear force in the plane of the area (N, lbf)
A = area (m2, in2)
A shear force lies in the plane of an area and is developed when external loads tend to cause the two segments of a body to slide over one another.
Strain (Deformation)
Strain is defined as "deformation of a solid due to stress".
- Normal strain - elongation or contraction of a line segment
- Shear strain - change in angle between two line segments originally perpendicular
Normal strain and can be expressed as
ε = dl / lo
= σ / E (3)
dl = change of length (m, in)
lo = initial length (m, in)
ε = strain - unit-less
E = Young's modulus (Modulus of Elasticity) (Pa, (N/m2), psi (lbf/in2))
- Young's modulus can be used to predict the elongation or compression of an object when exposed to a force
Note that strain is a dimensionless unit since it is the ratio of two lengths. But it also common practice to state it as the ratio of two length units - like m/m or in/in.
- Poisson's ratio is the ratio of relative contraction strain
Example - Stress and Change of Length
The rod in the example above is 2 m long and made of steel with Modulus of Elasticity 200 GPa (200×109 N/m2). The change of length can be calculated by transforming (3) to
dl = σ lo / E
= (127×106 Pa) (2 m) / (200×109 Pa)
= 0.00127 m
= 1.27 mm
Strain Energy
Stressing an object stores energy in it. For an axial load the energy stored can be expressed as
U = 1/2 Fn dl
U = deformation energy (J (N m), ft lb)
Young's Modulus - Modulus of Elasticity (or Tensile Modulus) - Hooke's Law
Most metals deforms proportional to imposed load over a range of loads. Stress is proportional to load and strain is proportional to deformation as expressed with Hooke's Law.
E = stress / strain
= σ / ε
= (Fn / A) / (dl / lo) (4)
E = Young's Modulus (N/m2) (lb/in2, psi)
Modulus of Elasticity, or Young's Modulus, is commonly used for metals and metal alloys and expressed in terms 106 lbf/in2, N/m2 or Pa. Tensile modulus is often used for plastics and is expressed in terms 105 lbf/in2 or GPa.
Shear Modulus of Elasticity - or Modulus of Rigidity
G = stress / strain
= τ / γ
= (Fp / A) / (s / d) (5)
G = Shear Modulus of Elasticity - or Modulus of Rigidity (N/m2) (lb/in2, psi)
τ = shear stress ((Pa) N/m2, psi)
γ = unit less measure of shear strain
Fp = force parallel to the faces which they act
A = area (m2, in2)
s = displacement of the faces (m, in)
d = distance between the faces displaced (m, in)
Bulk Modulus Elasticity
The Bulk Modulus Elasticity - or Volume Modulus - is a measure of the substance's resistance to uniform compression. Bulk Modulus of Elasticity is the ratio of stress to change in volume of a material subjected to axial loading.
Elastic Moduli
Elastic moduli for some common materials:
| Material | Young's Modulus - E - | Shear Modulus - G - | Bulk Modulus - K - |
| (GPa) (106 psi) | (GPa) (106 psi) | (GPa) (106 psi) | |
| Aluminum | 70 | 24 | 70 |
| Brass | 91 | 36 | 61 |
| Copper | 110 | 42 | 140 |
| Glass | 55 | 23 | 37 |
| Iron | 91 | 70 | 100 |
| Lead | 16 | 5.6 | 7.7 |
| Steel | 200 | 84 | 160 |
- 1 GPa = 109 Pa (N/m2)
- 106 psi = 1 Mpsi = 103 ksi
• Mechanics
• Statics
Engineering Materials - Properties
Some typical properties of engineering materials like steel, plastics, ceramics and composites.
Hooke's Law
Hooke's law - force, elongation and spring constant.
Malleability vs. Brittlenes vs. Ductility
Plastic deformation properties.
The Bulk Modulus - resistance to uniform compression - for some common metals and alloys.
Modulus of Rigidity
Poisson's Ratio – Definition, Values for Materials, and Applications
Poisson's ratio, a key material property describing the relationship between axial and lateral strain in solid materials. Typical Poisson's ratio values for metals, polymers, ceramics, and more, along with practical applications in engineering and mechanics.
Poisson's Ratios Metals
Process Pipes - Allowable Stress vs. Temperature
Allowable wall stress in pipes according ASME M31.3.
Rotating Bodies - Stress
Stress in rotating disc and ring bodies.
Calculate the stress in steam boiler shells caused by steam pressure.
Stress
Stress in Thick-Walled Cylinders or Tubes
Radial and tangential stress in thick-walled cylinders or tubes with closed ends - with internal and external pressure.
Stress in Thin-Walled Cylinders or Tubes
Hoop and longitudinal stress thin-walled tubes or cylinders.
Structural Lumber - Properties
Threaded Bolts - Stress Area
Threaded bolts tensile stress area.
Threaded Rods - Loads in Imperial Units
Weight rating of threaded hanger rods.
