Poisson's Ratios Metals
The Poisson's Ratio express
- the relative contraction strain (or transverse strain) normal to the applied load - to the relative extension strain (or axial strain) in the direction of the applied load
Poisson's ratio for some common metals:
Metal | Poisson's Ratio - μ - |
Aluminum | 0.33 |
Aluminum Bronze | 0.30 |
Beryllium | 0.024 - 0.03 |
Blackheart Cast Iron | 0.26 |
Bronze | 0.34 |
Copper | 0.36 |
Gold | 0.42 |
Lead | 0.40 - 0.45 |
Magnesium | 0.35 |
Mild Steel | 0.3 |
Molybdenum | 0.32 |
Naval Brass | 0.34 |
Nickel | 0.31 |
Phosphor Bronze | 0.33 |
Platinum | 0.39 |
Plutonium | 0.15 - 0.21 |
Silver | 0.37 |
Stainless Steel 304L | 0.3 |
Tantalum | 0.35 |
Thorium | 0.27 |
Tin | 0.33 |
Titanium | 0.3 |
Tungsten | 0.28 |
Uranium | 0.21 |
Wrought Iron | 0.3 |
Zinc | 0.25 |
• Mechanics
• Statics
Malleability vs. Brittlenes vs. Ductility
Plastic deformation properties.
Metals - Machinability
The machinability of some common metals.
Metals - Specific Heats
The Bulk Modulus - resistance to uniform compression - for some common metals and alloys.
Modulus of Rigidity
Poisson's Ratio – Definition, Values for Materials, and Applications
Poisson's ratio, a key material property describing the relationship between axial and lateral strain in solid materials. Typical Poisson's ratio values for metals, polymers, ceramics, and more, along with practical applications in engineering and mechanics.
Ratios and Proportions
The relative values between quantities - ratios and proportions.
