Poisson's Ratio – Definition, Values for Materials, and Applications
When a sample of material is stretched in one direction it tends to get thinner in the lateral direction - and if a sample is compressed in one direction it tends to get thicker in the lateral direction.
Poisson's ratio is
- the ratio of the relative contraction strain (transverse, lateral or radial strain) normal to the applied load - to the relative extension strain (or axial strain) in the direction of the applied load
Poisson's Ratio can be expressed as
μ = - εt / εl (1)
μ = Poisson's ratio
εt = transverse strain (m/m, ft/ft)
εl = longitudinal or axial strain (m/m, ft/ft)
Strain is defined as "deformation of a solid due to stress".
Longitudinal (or axial) strain can be expressed as
εl = dl / L (2)
εl = longitudinal or axial strain (dimensionless - or m/m, ft/ft)
dl = change in length (m, ft)
L = initial length (m, ft)
Contraction (or transverse, lateral or radial) strain can be expressed as
εt = dr / r (3)
εt = transverse, lateral or radial strain (dimensionless - or m/m, ft/ft)
dr = change in radius (m, ft)
r = initial radius (m, ft)
Eq. 1, 2 and 3 can be combined to
μ = - ( dr / r) / ( dl / L) (4)
Example - Stretching Aluminum
An aluminum bar with length 10 m and radius 100 mm (100×10-3 m) is stretched 5 mm (5×10-3 m) . The radial contraction in lateral direction can be rearranged to
dr = - μ ⋅ r ⋅ dl / L (5)
With Poisson's ratio for aluminum 0.334 - the contraction can be calculated as
dr = - 0.334 ⋅ ( 100 ⋅ 10-3 m) ( 5 ⋅ 10-3 m) / (10 m)
= 1.7 10-5 m
= 0.017 mm
Poisson's Ratios for Common Materials
For most common materials the Poisson's ratio is in the range 0 - 0.5. Typical Poisson's Ratios for some common materials are indicated below.
Material | Poisson's Ratio - μ - |
Upper limit | 0.5 |
Aluminum | 0.334 |
Aluminum, 6061-T6 | 0.35 |
Aluminum, 2024-T4 | 0.32 |
Beryllium Copper | 0.285 |
Brass, 70-30 | 0.331 |
Brass, cast | 0.357 |
Bronze | 0.34 |
Clay | 0.41 |
Concrete | 0.1 - 0.2 |
Copper | 0.355 |
Cork | 0 |
Glass, Soda | 0.22 |
Glass, Float | 0.2 - 0.27 |
Granite | 0.2 - 0.3 |
Ice | 0.33 |
Inconel | 0.27 - 0.38 |
Iron, Cast - gray | 0.211 |
Iron, Cast | 0.22 - 0.30 |
Iron, Ductile | 0.26 - 0.31 |
Iron, Malleable | 0.271 |
Lead | 0.431 |
Limestone | 0.2 - 0.3 |
Magnesium | 0.35 |
Magnesium Alloy | 0.281 |
Marble | 0.2 - 0.3 |
Molybdenum | 0.307 |
Monel metal | 0.315 |
Nickel Silver | 0.322 |
Nickel Steel | 0.291 |
Polystyrene | 0.34 |
Phosphor Bronze | 0.359 |
Rubber | 0.48 - ~0.5 |
Sand | 0.29 |
Sandy loam | 0.31 |
Sandy clay | 0.37 |
Stainless Steel 18-8 | 0.305 |
Steel, cast | 0.265 |
Steel, Cold-rolled | 0.287 |
Steel, high carbon | 0.295 |
Steel, mild | 0.303 |
Titanium (99.0 Ti) | 0.32 |
Wrought iron | 0.278 |
Z-nickel | 0.36 |
Zinc | 0.331 |
• Mechanics
Malleability vs. Brittlenes vs. Ductility
Plastic deformation properties.
Metals - Machinability
The machinability of some common metals.
The Bulk Modulus - resistance to uniform compression - for some common metals and alloys.
Modulus of Rigidity
Poisson's Ratios Metals
Ratios and Proportions
The relative values between quantities - ratios and proportions.
