The Bulk Modulus Elasticity - or Volume Modulus - is a measure of the substance's resistance to uniform compression.
Bulk Modulus of Elasticity is the ratio of stress to the change in volume in a material subjected to axial loading.
Typical values of bulk modulus for some metals and alloys are indicated below. Note that the values may vary widely.
MaterialBulk Modulus
- K -
(106 psi)(GPa)
Aluminum, various alloys 9.9 - 10.2 68 - 70
Boron Carbide (B4) 29 - 34.8 200 - 240
Brass, 70-30 15.7 108
Brass, cast 16.8 116
Concrete 0.87 - 4.1 6 - 28
Copper 17.9 123
Diamond (carbon) 80 - 93 550 - 640
Iron, cast 8.4 - 15.5 58 - 107
Iron, malleable 17.2 119
Magnesium alloy 4.8 33.1
Monel metal 22.5 155
Phosphor bronze 16.3 112
Silver 13.9 - 15.4 96 - 106
Stainless Steels (18-8) 23.6 163
Steel, cast 20.2 139
Steel, cold rolled 23.1 159
Steel, various 22.6 - 24.0 156 - 165
Tin 6.1 - 8.4 42 - 60
Tungsten 44.5 - 15.5 307 - 314
  • 1 GPa = 109 Pa (N/m2)
  • 1 GPa = 0.145 psi
Stainless steel with Bulk Modulus 163×109 Pa is approximate 80 times harder to compress than water with Bulk Modulus 2.15×109 Pa.
Bulk Modulus is related to Modulus of Elasticity and Poisson's Ratio as
K = E / 3 (1 - 2 r)                                                (1)
K = Bulk Modulus (Pa (N/m2), psi (lbf/in2)
E = Modulus of Elasticity (Pa (N/m2), psi (lbf/in2)
r = Poisson's Ratio
Material Properties
Bulk Modulus and Fluid Elasticities
Introduction to - and definition of - Bulk Modulus Elasticity commonly used to characterize the compressibility of fluids.
Concrete Properties
Properties of normal strength Portland cement concrete.
Metal Alloys - Specific Heats
Specific heat of metal alloys like brass, bronze and more.
Metals Strength vs. Temperature
The influence of temperature on the strength of metals.
Modulus of Rigidity
Poisson's Ratio – Definition, Values for Materials, and Applications
Poisson's ratio, a key material property describing the relationship between axial and lateral strain in solid materials. Typical Poisson's ratio values for metals, polymers, ceramics, and more, along with practical applications in engineering and mechanics.
Poisson's Ratios Metals
