Modulus of Rigidity
Modulus of Rigidity - G - (Shear Modulus) is the coefficient of elasticity for a shearing force. It is defined as
- "the ratio of shear stress to the displacement per unit sample length (shear strain)"
Modulus of Rigidity can be experimentally determined from the slope of a stress-strain curve created during tensile tests conducted on a sample of the material.
The definition of Modulus of Rigidity:
- the ratio of shear stress to the displacement per unit sample length (shear strain)
Modulus of Rigidity of some Common Materials
• Mechanics
• Statics
Bulk Modulus and Fluid Elasticities
Introduction to - and definition of - Bulk Modulus Elasticity commonly used to characterize the compressibility of fluids.
Engineering Materials - Properties
Some typical properties of engineering materials like steel, plastics, ceramics and composites.
The Bulk Modulus - resistance to uniform compression - for some common metals and alloys.
Metals Strength vs. Temperature
The influence of temperature on the strength of metals.
Poisson's Ratio
When a material is stretched in one direction it tends to get thinner in the other two directions.
Poisson's Ratios Metals
Polymers - Physical Properties
Densities, tensile strength, elongation, Youngs modulus and Brinell hardness.
Rotating Shafts - Torque
Torsional moments acting on rotating shafts.
Section Modulus - Unit Converter
Convert between Elastic Section Modulus units.
Shafts Torsion
The torsion of solid or hollow shafts - Polar Moment of Inertia of Area.
Softwood and Hardwood - Structural Strength Classes
Strength classes, bending stress and mean density of hardwood and softwood
Square Hollow Structural Sections (HSS) – Sizes, Strength & Specifications
Steel Angles - Unequal Legs
Stiffness
Stiffness is resistance to deflection.
Trusses
Common types of trusses.
Understanding Young’s Modulus: Definition, Values & Engineering Applications
Young's Modulus (or Tensile Modulus alt. Modulus of Elasticity) and Ultimate Tensile Strength and Yield Strength for materials like steel, glass, wood and many more.
