- ρ -
(103 kg/m3)
Material | Density - ρ - (103 kg/m3) | Tensile Modulus - E - (GPa) | Tensile Strength - σ - (MPa) | Specific Modulus - E / ρ - | Specific Strength - σ / ρ - | Maximum Service Temperature (oC) |
Cast Iron, grade 20 | 7.15 | 100 | 140 | 14.3 | 0.02 | 230 - 300 |
Steel, AISI 1045 | 7.7 - 8.03 | 205 | 585 | 26.3 | 0.073 | 500 - 650 |
Aluminum 2045-T4 | 2.7 | 73 | 450 | 27 | 0.17 | 150 - 250 |
Aluminum 6061-T6 | 2.7 | 69 | 270 | 25.5 | 0.10 | 150 - 250 |
Alumina | 3.8 | 350 | 170 | 92.1 | 0.045 | 1425 - 1540 |
MgO | 3.6 | 205 | 60 | 56.9 | 0.017 | 900 - 1000 |
Nylon 6/6 | 1.15 | 2 - 3.6 | 82 | 2.52 | 0.071 | 75 - 100 |
Polyethylene (HDPE) | 0.9 - 1.4 | 0.18 - 1.6 | 15 | |||
Polypropylene | 0.9 - 1.24 | 1.4 | 33 | 1.55 | 0.037 | 50 - 80 |
Epoxy | 1.25 | 3.5 | 69 | 2.8 | 0.055 | 80 - 215 |
Phenolic | 1.35 | 3.0 | 6 | 2.22 | 0.004 | 70 - 120 |
Common materials and average ultimate compression and tension strength.
An introduction to density, specific weight and specific gravity.
The influence of temperature on the strength of metals.
Chemical resistance of Polyester to products like Acetic acid, Diesel oil and others.
Young's Modulus (or Tensile Modulus alt. Modulus of Elasticity) and Ultimate Tensile Strength and Yield Strength for materials like steel, glass, wood and many more.
