Compression and Tension Strength of some common Materials
Average ultimate compression and tension strength of some common materials:
| Material | Compression Strength - σ - | Tension Strength - σ - | ||
| psi | MPa | psi | MPa | |
| Bricks, hard | 12000 | 80 | 400 | 2.8 |
| Bricks, light | 1000 | 7 | 40 | 0.28 |
| Brickwork, common quality | 1000 | 7 | 50 | 0.35 |
| Brickwork, best quality | 2000 | 14 | 300 | 2.1 |
| Granite | 19000 | 130 | 700 | 4.8 |
| Limestone | 9000 | 60 | 300 | 2.1 |
| Portland Cement, less than one month old | 2000 | 14 | 400 | 2.8 |
| Portland Cement, more than one year old | 3000 | 21 | 500 | 3.5 |
| Portland Concrete, 28 days old | 5000 | 35 | 200 | 1.4 |
| Portland Concrete, more than one year old | 6200 | 43 | 400 | 2.8 |
| Sandstone | 9000 | 60 | 300 | 2.1 |
| Slate | 14000 | 95 | 500 | 3.5 |
| Trap rock | 20000 | 140 | 800 | 5.5 |
- 1 MPa = 106 Pa = 1 N/mm2 = 145.0 psi (lbf/in2)
Brick Densities
Densities of common types of bricks.
Bricks - Quantity and Mortar Consumption
Estimate required quantities of bricks and mortar.
Concrete Properties
Properties of normal strength Portland cement concrete.
Engineering Materials - Properties
Some typical properties of engineering materials like steel, plastics, ceramics and composites.
Mortar Types
ASTM mortar types.
Softwood and Hardwood - Structural Strength Classes
Strength classes, bending stress and mean density of hardwood and softwood
