Values varies with product content and production processes.
Estimate required quantities of bricks and mortar.
Common materials and average ultimate compression and tension strength.
Concrete Masonry Unit Blocks (CMU) - dimensions.
Thermal conductivity coefficients for insulation materials, aluminum, asphalt, brass, copper, steel, gases and more.
