Bricks - Quantity and Mortar Consumption
Brick Size
Type | Nominal Size (in) | Actual (Specified) Size (in) | No. per Square Foot |
Standard | 4 x 2 2/3 x 8 | 3 5/8 x 2 1/4 x 8 | 6.3 |
Modular | 4 x 2 2/3 x 8 | 3 5/8 x 2 1/4 x 7 5/8 | 6.9 |
King | 3 3/8 x 3×10 | 3 x 2 5/8 x 9 5/8 | 4.8 |
Queen | 2 3/4 x 3×10 | 3 1/8 x 2 3/4 x 9 5/8 | 4.6 |
Engineer | 4 x 3 1/5 x 8 | 3 5/8 x 2 13/16 x 7 5/8 | 5.7 |
Economy | 4 x 4 x 8 | 3 5/8 x 3 5/8 x 7 5/8 | 4.5 |
Utility | 4 x 4 x 12 | 3 5/8 x 3 5/8 x 11 1/2 | 3.1 |
Jumbo | 4 x 3 x 8 | 3 5/8 x 2 3/4 x 8 | 5.5 |
Norman | 4 x 2 2/3 x 12 | 3 5/8 x 2 1/4 x 11 5/8 | 4.6 |
Jumbo Norman | 4 x 3 x 12 | 3 5/8 x 2 3/4 x 11 5/8 | |
Norwegian | 3 1/2 x 3 x 12 | 3 1/2 x 2 3/4 x 11 5/8 | 3.9 |
- actual or specified width and height - without mortar joint
- nominal width and height - including mortar joint
- the predominant mortar joint width used in construction is 3/8"
- How many bicks are needed? Use this tool to calculate the number of bricks needed.
Mortar Required for Common Bricks
Common bricks - 2 1/4 x 8 x 3 3/4 inches:
Joint Thickness (inches) | Mortar Required (ft3) | |
per 1000 bricks | per ft3 brick | |
1/4 | 9 | 0.2 |
3/8 | 14 | 0.3 |
1/2 | 20 | 0.4 |
- 1 ft3 = 0.02832 m3
- 1 in (inch) = 25.4 mm
BS EN 771-3: 2003
Brick | Length (mm) | Width (mm) | Height (mm) |
Standard | 215 | 102.5 | 65 |
Modular | 290 | 90 | 90 |
190 | 90 | 90 | |
190 | 90 | 65 |
Brick Walls - Selected Bond Patterns
- Stretcher bond
- Flemish garden wall bond
- English garden wall bond
- Flemish bond
- English bond
Brick Orientation
- stretcher
- shiner
- soldier
- sailor
- header
- rowlock
Brick Densities
Densities of common types of bricks.
Compression and Tension Strength of some common Materials
Common materials and average ultimate compression and tension strength.
Concrete - Water to Cement Ratios
Water vs. cement ratio when mixing concrete.
Concrete Mixtures
Cement, sand and gravel mixtures.
Concrete Properties
Properties of normal strength Portland cement concrete.
Masonry Blocks - Dimensions
Concrete Masonry Unit Blocks (CMU) - dimensions.
Maximizing Space: Fit Small Rectangles Inside a Larger Rectangle
Mortar Types
ASTM mortar types.
Solids - Densities
Densities of selected solids.
