Note! - the algorithm used for this tool is quite simple. Be aware that for some combinations of values more rectangles can be added by rearranging the layout.
Calculate area of intersecting circles
Convert between units of area.
Estimate required quantities of bricks and mortar.
The controid of square, rectangle, circle, semi-circle and right-angled triangle.
The equation for a circle
Calculate chord lengths when dividing the circumference of a circle into an equal number of segments.
Circumferences and areas of circles with diameters in inches.
Calculate the numbers of circles on the outside of an inner circle - like the geometry of rollers on a shaft.
Calculate the maximum number of circles within a rectangle - can be used to calculate the numbers of pipes or wires in a conduit or similar.
Radius and side lengths of equal areas, circles and squares.
Convert rectangular and oval duct geometry to a equivalent circular diameter - online calculator with imperial and SI-units.
Areas, diagonals and more - of geometric figures like rectangles, triangles, trapezoids ..
Concrete Masonry Unit Blocks (CMU) - dimensions.
A rectangle is square if the lengths of both diagonals are equal.
