Area of Intersecting Circles
The area of intersecting circles can be calculated as
Thanks to Eric Eberly for providing this information.
If radii r1, r2 and distance d between the centers are given - then the angles α1 and α2 can be calculated as
α1 = acos((d2 + r12 - r22) / (2 d r1))
α2 = acos((d2 + r22 - r12) / (2 d r2))
• Mathematics
Circle - the Chord Lengths when Divided in to Equal Segments
Calculate chord lengths when dividing the circumference of a circle into an equal number of segments.
Circle Equation
The equation for a circle
Circles on the Outside of a Circle
Calculate the numbers of circles on the outside of an inner circle - like the geometry of rollers on a shaft.
Circles within a Rectangle - Calculator
Calculate the maximum number of circles within a rectangle - can be used to calculate the numbers of pipes or wires in a conduit or similar.
Elementary Curves
Ellipse, circle, hyperbola, parabola, parallel, intersecting and coincident lines.
Elementary Surfaces
Ellipsoid, sphere, hyperboloid, cone and more.
Equal Areas - Circles vs. Squares
Radius and side lengths of equal areas, circles and squares.
Geometric Shapes - Areas
Areas, diagonals and more - of geometric figures like rectangles, triangles, trapezoids ..
Length of a Spiral
Calculate the length of a spiral or the length of material contained in a roll.
Maximizing Space: Fit Small Rectangles Inside a Larger Rectangle
