Circle - Equation
Unit Circle
The equation of a unit circle - where the center of the circle is located in the origo of the coordinate system and the radius = 1 - can be expressed as
x2 + y2 = 1                                (1)
Standard Form
The standard form for the equation of a circle can be expressed as
(x - a)2 + (y - b)2 = r2                            (2)
a = x coordinate position of the circle center
b = y coordinate position of the circle center
r = circle radius
General Form
The general form for the equation of a circle can be expressed as
x2 + y2 + A x + B y + C = 0                                  (3)
A, B, C = constants
Radius of circle
r = (a2 + b2 - C) 1/2                                       (4)
Coordinates in the Circle Centre
a = - A / 2                                   (5a)
b = - B / 2                                   (5b)
Mathematics
Area of Intersecting Circles
Calculate area of intersecting circles
Cartesian Coordinate System - Distance and Intermediate Position Between Two Points
Distance and intermediate position between two point in a cartesian x and y coordinate system.
Centroids of Plane Areas
The controid of square, rectangle, circle, semi-circle and right-angled triangle.
Circle - the Chord Lengths when Divided in to Equal Segments
Calculate chord lengths when dividing the circumference of a circle into an equal number of segments.
Circles - Circumferences and Areas
Circumferences and areas of circles with diameters in inches.
Distance between 3D Points
Distance between two points in a three dimension x, y and z coordinate system - online calculator.
Elementary Curves
Ellipse, circle, hyperbola, parabola, parallel, intersecting and coincident lines.
Equal Areas - Circles vs. Squares
Radius and side lengths of equal areas, circles and squares.
Geometric Shapes - Areas
Areas, diagonals and more - of geometric figures like rectangles, triangles, trapezoids ..
Polar vs. Cartesian Coordinates
Convert between Cartesian and Polar coordinates.
Radians vs. Degrees
Smaller Rectangles within a Larger Rectangle
