Centroids of Plane Areas
The centroid of an area is the point where the whole area is considered to be concentrated.
Square
Distance
x = a / 2 (1a)
y = a / 2 (1b)
Area
A = a2 (1c)
Rectangle
Distance
x = a / 2 (2a)
y = b / 2 (2b)
Area
A = a b (2c)
Circle
Distance
x = r (3a)
y = r (3b)
Area
A = π r2 (3c)
Semi-Circle
Distance
x = 4 r / (3 π) (4a)
y = r (4b)
Area
A = π r2/ 2 (4c)
Right-angled Triangle
Distance
x = b / 3 (5a)
y = h / 3 (5b)
Area
A = b h / 2 (5c)
• Mathematics
Area Units Converter
Convert between units of area.
Circle Equation
The equation for a circle
Circles - Circumferences and Areas
Circumferences and areas of circles with diameters in inches.
Circles on the Outside of a Circle
Calculate the numbers of circles on the outside of an inner circle - like the geometry of rollers on a shaft.
Elementary Curves
Ellipse, circle, hyperbola, parabola, parallel, intersecting and coincident lines.
Equal Areas - Circles vs. Squares
Radius and side lengths of equal areas, circles and squares.
Geometric Shapes - Areas
Areas, diagonals and more - of geometric figures like rectangles, triangles, trapezoids ..
Hexagons and Squares - Diagonal Lengths
Distances between corners for hexagons and squares.
Length of a Spiral
Calculate the length of a spiral or the length of material contained in a roll.
Maximizing Space: Fit Small Rectangles Inside a Larger Rectangle
Pythagorean Theorem
Verifying square corners.
Right Angled Triangle
Right angled triangle equations.
Solids - Volumes and Surfaces
The volume and surface of solids like rectangular prism, cylinders, pyramids, cones and spheres - online calculator.
Trigonometric Functions
Sine, cosine and tangent - the natural trigonometric functions.
