Solids - Volumes and Surfaces
Cube
all figures made with SketchUp and the Engineering ToolBox SketchUp Extension
Volume
V = a3 (1)
V = volume (m3, ft3)
a = side (m, ft)
Surface Area
A0 = 6 a2 (1b)
A0 = surface area (m2, ft2)
Diagonal
d = a 31/2 (1c)
d = inside diagonal (m, ft)
Diagonal of Cube Face
ds = a 21/2 (1d)
Cuboid - Square Prism
Volume
V = a b c (2)
V = volume of solid (m3, ft3)
a = length of rectangular prism (m, ft)
b = width of rectangular prism (m, ft)
c = height of rectangular prism (m, ft)
Diagonal
d = (a2 + b2 + c2)1/2 (2b)
Surface Area
A0 = 2 (a b + a c + b c) (2c)
A0 = surface area of solid (m2, ft2)
Volume:
Surface:
Parallelepiped
Volume
V = A1 h (3a)
A1 = side area (m2, ft2)
Related Sketchup Components from The Engineering ToolBox
Geometric Figures - Cylinders, Boxes, Cones, Planes, Spheres, Lines, Curves and more..
- free Engineering ToolBox plugin for use with the amazing Sketchup 3D drawing/model application.
Cylinder
Volume
V = π r2 h = (π / 4) d2 h (4a)
d = diameter of cylinder (m, ft)
r = radius of cylinder (m, ft)
h = height of cylinder (m, ft)
Surface
A = 2 π r h + 2 π r2 (4b)
Volume:
Surface:
Hollow Cylinder
Volume
V = π/4 h (D2 - d2) (5)
Pyramid
Volume
V = 1/3 h A1 (6)
A1 = area of base (m2, ft2)
h = perpendicular height of pyramid (m, ft)
Surface
A = ∑ sum of areas of triangles forming sides + Ab (6b)
the surface areas of the triangular faces will have different formulas for different shaped bases
Volume:
Frustum of Pyramid
Volume
V = (h / 3) (A1 + A2+ (A1 A2)1/2) (7)
Cone
Volume
V = 1/3 π r2 h (8a)
r = radius of cone base (m, ft)
h = height of cone (m, ft)
Surface
A = π r l + π r2 (8b)
l = (r2+ h2)1/2 = length of cone side (m, ft)
Volume:
Surface:
Side
m = (h2+ r2)1/2 (8c)
A2 / A1 = x2 / h2 (8d)
Frustum of Cone
Volume
V = π/12 h (D2+ D d + d2) (9a)
m = (((D - d) / 2)2+ h2)1/2 (9c)
Sphere
Volume
V = 4/3 π r3
= 1/6 π d3 (10a)
r = radius of sphere (m, ft)
Surface
A = 4 π r2
= π d2 (10b)
Volume:
Surface:
Spheres with Fractional Diameters - Surface Areas and Volumes
Fraction Diameter - d – (inch) | Decimal Diameter - d – (inch) | Decimal Radius – r – (inch) | Surface Area - A – (in2) | Volume - V - (in3) |
1/64 | 0.015625 | 0.007813 | 0.0007670 | 0.0000020 |
1/32 | 0.031250 | 0.015625 | 0.0030680 | 0.0000160 |
3/64 | 0.046875 | 0.023438 | 0.0069029 | 0.0000539 |
1/64 | 0.062500 | 0.031250 | 0.0122718 | 0.0001278 |
5/64 | 0.078125 | 0.039063 | 0.0191748 | 0.0002497 |
3/32 | 0.093750 | 0.046875 | 0.0276117 | 0.0004314 |
7/64 | 0.109375 | 0.054688 | 0.0375825 | 0.0006851 |
1/8 | 0.125000 | 0.062500 | 0.0490874 | 0.0010227 |
9/64 | 0.140625 | 0.070313 | 0.0621262 | 0.0014561 |
5/32 | 0.156250 | 0.078125 | 0.0766990 | 0.0019974 |
11/64 | 0.171875 | 0.085938 | 0.0928058 | 0.0026585 |
3/16 | 0.187500 | 0.093750 | 0.1104466 | 0.0034515 |
13/64 | 0.203125 | 0.101563 | 0.1296214 | 0.0043882 |
7/32 | 0.218750 | 0.109375 | 0.1503301 | 0.0054808 |
15/64 | 0.234375 | 0.117188 | 0.1725728 | 0.0067411 |
1/4 | 0.250000 | 0.125000 | 0.1963495 | 0.0081812 |
17/64 | 0.265625 | 0.132813 | 0.2216602 | 0.0098131 |
9/32 | 0.281250 | 0.140625 | 0.2485049 | 0.0116487 |
19/64 | 0.296875 | 0.148438 | 0.2768835 | 0.0137000 |
5/16 | 0.312500 | 0.156250 | 0.3067962 | 0.0159790 |
21/64 | 0.328125 | 0.164063 | 0.3382428 | 0.0184977 |
11/32 | 0.343750 | 0.171875 | 0.3712234 | 0.0212680 |
23/64 | 0.359375 | 0.179688 | 0.4057379 | 0.0243020 |
3/8 | 0.375000 | 0.187500 | 0.4417865 | 0.0276117 |
25/64 | 0.390625 | 0.195313 | 0.4793690 | 0.0312089 |
13/32 | 0.406250 | 0.203125 | 0.5184855 | 0.0351058 |
27/64 | 0.421875 | 0.210938 | 0.5591360 | 0.0393142 |
7/16 | 0.437500 | 0.218750 | 0.6013205 | 0.0438463 |
29/64 | 0.453125 | 0.226563 | 0.6450389 | 0.0487139 |
15/32 | 0.468750 | 0.234375 | 0.6902914 | 0.0539290 |
31/64 | 0.484375 | 0.242188 | 0.7370778 | 0.0595037 |
1/2 | 0.500000 | 0.250000 | 0.7853982 | 0.0654498 |
33/64 | 0.515625 | 0.257813 | 0.8352525 | 0.0717795 |
17/32 | 0.531250 | 0.265625 | 0.8866409 | 0.0785047 |
35/64 | 0.546875 | 0.273438 | 0.9395632 | 0.0856373 |
9/16 | 0.562500 | 0.281250 | 0.9940196 | 0.0931893 |
37/64 | 0.578125 | 0.289063 | 1.0500098 | 0.1011728 |
19/32 | 0.593750 | 0.296875 | 1.1075341 | 0.1095997 |
39/64 | 0.609375 | 0.304688 | 1.1665924 | 0.1184820 |
5/8 | 0.625000 | 0.312500 | 1.2271846 | 0.1278317 |
41/64 | 0.640625 | 0.320313 | 1.2893109 | 0.1376608 |
21/32 | 0.656250 | 0.328125 | 1.3529711 | 0.1479812 |
43/64 | 0.671875 | 0.335938 | 1.4181652 | 0.1588050 |
11/16 | 0.687500 | 0.343750 | 1.4848934 | 0.1701440 |
45/64 | 0.703125 | 0.351563 | 1.5531555 | 0.1820104 |
23/32 | 0.718750 | 0.359375 | 1.6229517 | 0.1944161 |
47/64 | 0.734375 | 0.367188 | 1.6942818 | 0.2073730 |
3/4 | 0.750000 | 0.375000 | 1.7671459 | 0.2208932 |
49/64 | 0.765625 | 0.382813 | 1.8415439 | 0.2349887 |
25/32 | 0.781250 | 0.390625 | 1.9174760 | 0.2496714 |
51/64 | 0.796875 | 0.398438 | 1.9949420 | 0.2649532 |
13/16 | 0.812500 | 0.406250 | 2.0739420 | 0.2808463 |
53/64 | 0.828125 | 0.414063 | 2.1544760 | 0.2973626 |
27/32 | 0.843750 | 0.421875 | 2.2365440 | 0.3145140 |
55/64 | 0.859375 | 0.429688 | 2.3201459 | 0.3323126 |
7/8 | 0.875000 | 0.437500 | 2.4052819 | 0.3507703 |
57/64 | 0.890625 | 0.445313 | 2.4919518 | 0.3698991 |
29/32 | 0.906250 | 0.453125 | 2.5801557 | 0.3897110 |
59/64 | 0.921875 | 0.460938 | 2.6698936 | 0.4102180 |
15/16 | 0.937500 | 0.468750 | 2.7611654 | 0.4314321 |
61/64 | 0.953125 | 0.476563 | 2.8539713 | 0.4533652 |
31/32 | 0.968750 | 0.484375 | 2.9483111 | 0.4760294 |
63/64 | 0.984375 | 0.492188 | 3.0441849 | 0.4994366 |
1 | 1.000000 | 0.500000 | 3.1415927 | 0.5235988 |
Zone of a Sphere
V = π/6 h (3a2+ 3b2+ h) (11a)
Am = 2 π r h (11b)
A0 = π (2 r h + a2+ b2) (11c)
Segment of a Sphere
V = π/6 h (3/4 s2+ h2)
= π h2 (r - h/3) (12a)
Am = 2 π r h
= π/4 (s2+ 4 h2) (12b)
Sector of a Sphere
V = 2/3 π r2 h (13a)
A0 = π/2 r (4 h + s) (13b)
Sphere with Cylindrical Boring
V = π/6 h3 (14a)
A0 = 4 π ((R + r)3 (R - r))1/2
= 2 π h (R + r) (14b)
h = 2 (R2- r2)1/2 (14c)
Sphere with Conical Boring
V = 2/3 π R2 h (15a)
A0 = 2 π R (h + (R2 - h2 / 4)1/2) (15b)
h = 2 (R2 - r2)1/2 (15c)
Torus
V = π2/4 D d2 (16a)
A0 = π2 D d (16b)
Sliced Cylinder
V = π/4 d2 h
= π r2 ((h1 + h2) / 2) (17a)
Am = π d h
= 2 π r ((h1 + h2) / 2) (17b)
Am = side walls area
A0 = π r (h1 + h2 + r + (r2 + (h1 - h2)2 / 4)1/2) (17c)
A0 = surface area
Ungula
V = 2/3 r2 h (18a)
Am = 2 r h (18b)
A0 = Am + π/2 r2+ π/2 r (r2+ h2)1/2 (18c)
Barrel
V ≈ π/12 h (2 D2+ d2) (19a)
• Basics
• Mathematics
Area Units Converter
Convert between units of area.
Centroids of Plane Areas
The controid of square, rectangle, circle, semi-circle and right-angled triangle.
Cooking Units Volume Converter - U.S. and Metric Units
Convert between cooking liquid and dry measuring US and metric volume units.
Cooking Volumes - U.S. Unit Converter
Convert between US cooking volume units.
Cylindrical Tanks - Volumes
Volume in US gallons and liters.
Equal Areas - Circles vs. Squares
Radius and side lengths of equal areas, circles and squares.
Weight of round bars.
Pipes with Water Content - Weight and Volume
Estimate water content in pipes - weight and volume.
Rectangular Tanks - Volumes
Tank volume per foot depth.
Solids - Melting and Boiling Temperatures
Melting and boiling temperatures of some products.
Squaring with Diagonal Measurements
A rectangle is square if the lengths of both diagonals are equal.
Volume Units Converter
Convert between common volume units like cubic metre, cubic feet, cubic inches and more.
