Volume Units Converter
Volume Units Online Calculator
The calculator below can used to convert between common volume units:
Volume Units Converting Table
The table below can be used to convert between common volume units.
Convert from Multiply by
Convert to
cubic inches cubic feet cubic yards us liquid gallons us dry gallons imp liquid gallons barrels (oil) cups fluid ounces (UK) fluid ounces (US) pints (UK)
cubic metre 6.1 104 35.3 1.308 264.2 227 220 6.29 4227 3.52 104 3.38 104 1760
cubic decimetre 61.02 0.035 1.3 10-3 0.264 0.227 0.22 0.006 4.23 35.2 33.8 1.76
cubic centimetre 0.061 3.5 10-5 1.3 10-6 2.64 10-4 2.27 10-4 2.2 10-4 6.29 10-6 4.2 10-3 3.5 10-2 3.34 10-2 1.76 10-3
cubic millimetre 6.1 10-5 3.5 10-8 1.31 10-9 2.64 10-7 2.27 10-7 2.2 10-7 6.3 10-9 4.2 10-6 3.5 10-5 3.4 10-5 1.76 10-6
hectoliters 6.1 103 3.53 0.13 26.4 22.7 22 0.63 423 3.5 103 3381 176
liters 61 3.5 10-2 1.3 10-3 0.26 0.23 0.22 6.3 10-3 4.2 35.2 33.8 1.76
centiliters 0.61 3.5 10-4 1.3 10-5 2.6 10-3 2.3 10-3 2.2 10-3 6.3 10-5 4.2 10-2 0.35 0.338 1.76 10-2
milliliters 6.1 10-2 3.5 10-5 1.3 10-6 2.6 10-4 2.3 10-4 2.2 10-4 6.3 10-6 4.2 10-3 3.5 10-2 3.4 10-2 1.76 10-3
cubic inches 1 5.79 10-4 2.1 10-5 4.3 10-3 3.7 10-3 3.6 10-3 10-4 6.9 10-2 0.58 0.55 2.9 10-2
cubic feet 1728 1 0.037 7.48 6.43 6.23 0.18 119.7 997 958 49.8
cubic yards 4.7 104 27 1 202 173.6 168.2 4.8 3232 2.69 104 2.59 104 1345
us liquid gallons 231 0.134 4.95 10-3 1 0.86 0.83 0.024 16 133.2 128 6.7
us dry gallons 268.8 0.156 5.76 10-3 1.16 1 0.97 0.028 18.62 155 148.9 7.75
imp liquid gallons 277.4 0.16 5.9 10-3 1.2 1.03 1 0.029 19.2 160 153.7 8
barrels (oil) 9702 5.61 0.21 42 36.1 35 1 672 5596 5376 279.8
cups 14.4 8.4 10-3 3.1 10-4 6.2 10-2 5.4 10-2 5.2 10-2 1.5 10-3 1 8.3 8 0.4
fluid ounces (UK) 1.73 10-3 3.7 10-5 7.5 10-3 6.45 10-3 6.25 10-3 1.79 10-4 0.12 1 0.96 5 10-2
fluid ounces (US) 1.8 10-3 3.87 10-5 7.8 10-3 6.7 10-3 6.5 10-3 1.89 10-4 0.13 1.04 1 0.052
pints (UK) 34.7 0.02 7.4 10-4 0.15 0.129 0.125 3.57 10-3 2.4 20 19.2 1
Convert to
cubic metre cubic decimetre cubic centimetre cubic millimetre hectoliters liters centiliters milliliters
cubic meters 1 103 106 109 10 103 105 106
cubic decimeters 10-3 1 103 106 0.01 1 100 103
cubic centimeters 10-6 10-3 1 103 10-5 10-3 0.1 1
cubic millimeters 10-9 10-6 10-3 1 10-8 10-6 10-4 10-3
hectoliters 0.1 102 105 108 1 102 104 105
liters 10-3 1 103 106 10-2 1 102 103
centiliters 10-5 10-2 10 104 10-4 10-2 1 10
milliliters 10-6 10-3 1 103 10-5 10-3 0.1 1
cubic inches 1.6 10-5 1.6 10-2 16.4 1.64 104 1.64 10-4 1.64 10-2 1.64 16.4
cubic feet 2.8 10-2 28.3 2.83 104 2.83 107 0.28 28.3 2.83 103 2.83 104
cubic yards 0.765 765 7.65 105 7.65 108 7.65 765 7.65 104 7.65 105
us liquid gallons 3.79 10-3 3.79 3.79 103 3.79 106 3.79 10-2 3.79 379 3.79 103
us dry gallons 4.4 10-3 4.4 4.4 103 4.4 106 4.4 10-2 4.4 440 4.4 103
imp liquid gallons 4.55 10-3 4.55 4.55 103 4.55 106 4.56 10-2 4.55 455 4.55 103
barrels (oil) 0.16 159 1.59 105 1.59 108 1.59 159 1.59 104 1.59 105
cups 2.4 10-4 0.24 236.6 2.37 105 2.37 10-3 0.236 23.7 236.6
fluid ounces (UK) 2.8 10-5 2.8 10-2 28.4 2.8 104 2.8 10-4 2.8 10-2 2.84 28.4
fluid ounces (US) 2.96 10-5 2.96 10-2 29.6 2.96 104 2.96 10-4 2.96 10-2 2.96 29.6
pints (UK) 5.68 10-4 0.568 568 5.68 105 5.68 10-3 0.568 56.8 568
Other Volume Units
  • 1 m3 = 27.496 bushels (UK)
  • 1 m3 = 28.378 bushels (US)
  • 1 m3 = 0.001 cubic decameters
  • 1 m3 = 1759.8 pints (UK)
  • 1 m3 = 1816.2 pints dry (US)
  • 1 m3 = 2113.4 pints liquid (US)
  • 1 m3 = 879.9 quarts (UK)
  • 1 m3 = 908.1 quarts dry (US)
  • 1 m3 = 1056.7 quarts liquid (US)
  • 1 m3 = 67628 table spoons
  • 1 m3 = 202884 tea spoons
  • 1 peck = 8 dry quarts
  • 1 hogshead  = 8.42184 cubic feet
US gallon to liter Converter
Download and print US gallon to liter Converter!
Basics
The SI-system, unit converters, physical constants, drawing scales and more.
Cooking Units Volume Converter - US and Metric Units
Convert between cooking liquid and dry measuring US and metric volume units.
Cooking Volume Units Converter
Convert between different liquid cooking volume units.
Parts per Million - ppm
ppm - or parts per million - is commonly used as a unit of concentration.
Rectangular Tanks - Volumes
Tank volume per foot depth.
Solids - Volumes and Surfaces
The volume and surface of solids like rectangular prism, cylinders, pyramids, cones and spheres - online calculator.
Unit Factor Method
Volume Converting Chart - Gallons vs. Cubic Feet vs. Cubic Meters and more
Convert between volume units like U.S. liquid gallons, U.K. liquid gallons, cubic feet, cubic metre and more.
