Pipes with Water Content - Weight and Volume
- Calculate Pipe Weight - Weight calculating formulas for liquid filled pipes
Pipe Size (inside diameter) (in)
| Water Content | |||
Volume | Weight (lb/ft) | Volume/Weight | ||
(in3/ft) | (gallons/ft) | (liter/m, kg/m) | ||
1/4 | 0.59 | 0.003 | 0.02 | 0.030 |
3/8 | 1.33 | 0.006 | 0.05 | 0.074 |
1/2 | 2.36 | 0.010 | 0.09 | 0.13 |
3/4 | 5.30 | 0.023 | 0.19 | 0.28 |
1 | 9.43 | 0.041 | 0.34 | 0.51 |
1 1/4 | 14.7 | 0.064 | 0.53 | 0.79 |
1 1/2 | 21.2 | 0.092 | 0.77 | 1.1 |
2 | 37.7 | 0.163 | 1.36 | 2.0 |
2 1/2 | 58.9 | 0.255 | 2.13 | 3.2 |
3 | 84.8 | 0.367 | 2.31 | 3.4 |
4 | 150.8 | 0.653 | 5.44 | 8.1 |
5 | 235.6 | 1.02 | 8.50 | 13 |
6 | 339.3 | 1.47 | 12.2 | 18 |
8 | 603.2 | 2.61 | 21.8 | 32 |
10 | 942.5 | 4.08 | 34.0 | 51 |
12 | 1357.2 | 5.88 | 49.0 | 73 |
15 | 2120.6 | 9.18 | 76.5 | 114 |
- 1 lb/ft = 1.49 kg/m
- 1 gal(US)/ft = 12.4 liter/m
Note that for most pipes Nominal Size is not equal to inside diameter. For exact volumes - check the pipe documentation or standard - and use the calculator below.
The volume weight for other liquids can be calculated when compensated for density.
Example - Water Content in Pipe
The water volume in a 12 m long 2" pipe can be calculated as
(2.0 liter/m) (12 m)
= 24 liter
Pipes - Volume Calculator
This calculator can be used to calculate volume of water or other liquids in pipes. The calculator is generic and can be used for any units as long as the use of units are consistent. If input is m the result is m3/m and so on.
Use the volume converter in the left column for other units.
ANSI Steel Pipe Schedule 40 Chart: Dimensions, Weights & Specifications
Ice Loaded Pipelines
Ice coat weight on horizontal pipe lines.
NPS (Nominal Pipe Size) Guide: Dimensions, Charts & Specifications
The size of pipes, fittings, flanges and valves are often given in inches as NPS - Nominal Pipe Size, or in metric units as DN - 'Diametre Nominal'.
Pipe Weight Calculator
Pipes - Nominal Wall Thickness
Nominal wall thickness of seamless and welded carbon and alloy steel pipes
Pipes - Relative Capacity
Relative capacity between larger and smaller pipes.
Pipes and Tubes - Water Content
Water content in steel pipes and copper tubes.
Solids - Volumes and Surfaces
The volume and surface of solids like rectangular prism, cylinders, pyramids, cones and spheres - online calculator.
Volume in Horizontal Pipes or Cylindrical Tanks
Liquid content in partly filled horizontal pipes or tanks.
Welded Steel Pipes - Weights
Nominal weights of welded steel pipes ranging 26 - 60 inches.
