ANSI Steel Pipe Schedule 40 Chart: Dimensions, Weights & Specifications
Based on ASTM A53 - Standard Specification for Pipe, Steel, Black and Hot-Dipped, Zinc-Coated, Welded and Seamless.
For full table with Length vs. External and Internal Surface, Volume, Weight and Number of Threads - rotate the screen!
| Pipe Size (in) | Diameter (in) | Nominal Thickness (in) | Transverse Areas (in2) | Length of Pipe (ft per sq. foot of surface) | Volume (ft3/ft) | Weight | Number of Threads per inch of Screw | |||||
| External | Internal | External | Internal | Steel | External Surface (ft) | Internal Surface (ft) | (lb/ft) | (kg/m) | ||||
| 1/8 | 0.405 | 0.27 | 0.07 | 0.13 | 0.06 | 0.07 | 9.43 | 14.20 | 0.0004 | 0.24 | 0.36 | 27 |
| ¼ | 0.540 | 0.36 | 0.09 | 0.23 | 0.10 | 0.13 | 7.07 | 10.49 | 0.0007 | 0.42 | 0.63 | 18 |
| 3/8 | 0.675 | 0.49 | 0.09 | 0.36 | 0.19 | 0.17 | 5.66 | 7.75 | 0.0013 | 0.57 | 0.84 | 18 |
| ½ | 0.840 | 0.62 | 0.11 | 0.55 | 0.30 | 0.25 | 4.55 | 6.14 | 0.0021 | 0.85 | 1.26 | 14 |
| ¾ | 1.050 | 0.82 | 0.11 | 0.87 | 0.53 | 0.33 | 3.64 | 4.64 | 0.0037 | 1.13 | 1.68 | 14 |
| 1 | 1.315 | 1.05 | 0.13 | 1.36 | 0.86 | 0.49 | 2.90 | 3.64 | 0.0060 | 1.68 | 2.50 | 11 ½ |
| 1 ¼ | 1.660 | 1.38 | 0.14 | 2.16 | 1.50 | 0.67 | 2.30 | 2.77 | 0.0104 | 2.27 | 3.38 | 11 ½ |
| 1 ½ | 1.900 | 1.61 | 0.15 | 2.84 | 2.04 | 0.80 | 2.01 | 2.37 | 0.0141 | 2.72 | 4.04 | 11 ½ |
| 2 | 2.375 | 2.07 | 0.15 | 4.43 | 3.36 | 1.08 | 1.61 | 1.85 | 0.0233 | 3.65 | 5.43 | 11 ½ |
| 2 ½ | 2.875 | 2.47 | 0.20 | 6.49 | 4.79 | 1.70 | 1.33 | 1.55 | 0.0333 | 5.79 | 8.62 | 8 |
| 3 | 3.500 | 3.07 | 0.22 | 9.62 | 7.39 | 2.23 | 1.09 | 1.25 | 0.0513 | 7.58 | 11.27 | 8 |
| 3 ½ | 4.000 | 3.55 | 0.23 | 12.56 | 9.89 | 2.68 | 0.95 | 1.08 | 0.0687 | 9.11 | 13.56 | 8 |
| 4 | 4.500 | 4.03 | 0.24 | 15.90 | 12.73 | 3.17 | 0.85 | 0.95 | 0.0884 | 10.79 | 16.06 | 8 |
| 5 | 5.563 | 5.05 | 0.26 | 24.30 | 20.00 | 4.30 | 0.69 | 0.76 | 0.1389 | 14.61 | 21.74 | 8 |
| 6 | 6.625 | 6.07 | 0.28 | 34.47 | 28.89 | 5.58 | 0.58 | 0.63 | 0.2006 | 18.97 | 28.23 | 8 |
| 8 | 8.625 | 7.98 | 0.32 | 58.42 | 50.02 | 8.40 | 0.44 | 0.48 | 0.3552 | 28.55 | 42.49 | 8 |
| 10 | 10.750 | 10.02 | 0.37 | 90.76 | 78.85 | 11.90 | 0.36 | 0.38 | 0.5476 | 40.48 | 60.24 | 8 |
| 12 | 12.750 | 11.94 | 0.41 | 127.64 | 111.90 | 15.74 | 0.30 | 0.32 | 0.7763 | 53.60 | 79.77 | 8 |
| 14 | 14.000 | 13.13 | 0.44 | 153.94 | 135.30 | 18.64 | 0.27 | 0.28 | 0.9354 | 63.00 | 93.75 | 8 |
| 16 | 16.000 | 15.00 | 0.50 | 201.05 | 176.70 | 24.35 | 0.24 | 0.25 | 1.2230 | 78.00 | 116.08 | 8 |
| 18 | 18.000 | 16.88 | 0.56 | 254.85 | 224.00 | 30.85 | 0.21 | 0.23 | 1.5550 | 105.00 | 156.26 | 8 |
| 20 | 20.000 | 18.81 | 0.59 | 314.15 | 278.00 | 36.15 | 0.19 | 0.20 | 1.9260 | 123.00 | 183.05 | 8 |
| 24 | 24.000 | 22.63 | 0.69 | 452.40 | 402.10 | 50.30 | 0.16 | 0.17 | 2.7930 | 171.00 | 254.48 | 8 |
ASTM A53 pipe - also referred to as ASME SA53 pipe - is intended for mechanical and pressure applications. Can be used in steam, water, gas and air lines. Suitable for welding and forming like coiling, bending and flanging.
- 1 in2 = 645.2 mm2 = 6.452 cm2 = 6.452×10-4 m2
- 1 ft (foot) = 0.3048 m
• Piping Codes and Standards
• Piping Systems
ASME/ANSI B16.5 Flanges and Bolt Dimensions - Class 150 to 2500
Diameters and bolt circles for standard ASME B16.5 flanges - 1/4 to 24 inches - Class 150 to 2500.
ASME/ANSI B36.10/19 - Carbon, Alloy and Stainless Steel Pipe - Dimensions
Pressure loss in compressed air pipe lines.
EN 10312 - Welded Stainless Steel Tubes for the Conveyance of Aqueous Liquids Including Water for Human Consumption - Dimensions
Dimensions of welded stainless steel tubes according EN 10312.
Hot Water Heating System Online Design Application
Pressure loss nomogram for hot water steel pipes.
Ice Loaded Pipelines
Ice coat weight on horizontal pipe lines.
NPS (Nominal Pipe Size) Guide: Dimensions, Charts & Specifications
The size of pipes, fittings, flanges and valves are often given in inches as NPS - Nominal Pipe Size, or in metric units as DN - 'Diametre Nominal'.
Pipe and Tubing Formulas
Pipe and Tube Equations - moment of inertia, section modulus, traverse metal area, external pipe surface and traverse internal area - imperial units
Pipe Weight Calculator
Pipes - Nominal Wall Thickness
Nominal wall thickness of seamless and welded carbon and alloy steel pipes
Pipes and Tubes - Imperial vs. Metric Sizes
SI vs. Imperial pipe sizes.
Pipes and Tubes - Water Content
Water content in steel pipes and copper tubes.
Pipes with Water Content - Weight and Volume
Estimate water content in pipes - weight and volume.
Piping Equations
Calculate cross-sectional areas, weight of empty pipes, weight of pipes filled with water, inside and outside surface areas.
Piping Materials - Cost Ratios
Sizing Steam Pipes (kg/h)
Steam is a compressible gas where pipe line mass flow capacity depends on steam pressure.
Sizing Steam Pipes (lb/h)
Steam Flow Rate vs. Pressure Drop - Schedule 40 Pipe
Flow rate (lb/h) and pressure drop per 100 feet of pipe.
Steam Pipes - Sizing
Sizing of steam pipe lines - major and minor loss in steam distribution systems.
Steel Pipes - Bundling Schedules Length and Weight
Bundling schedules for standard weight and extra strong steel pipes.
Steel Pipes - Maximum Water Flow Capacities vs. Size
Maximum water flow capacities in steel pipes - pipe dimensions ranging 2 - 24 inches.
Steel Pipes - Viscous Liquid Flow and Friction Loss
Friction loss in schedule 40 steel pipe with viscous liquids - viscosities ranging from water to oil.
Steel Pipes - Weight
Steel Pipes Schedule 40 - Pressure Loss
Water flow and pressure loss in schedule 40 steel pipes - Imperial and SI units - gallons per minute, liters per second and cubic meters per hour.
Steel Pipes Schedule 40 - Velocity Head vs. Water Flow
Velocity head can be used to calculate minor pressure or head loss in fluid flow systems.
Threaded & Socket Welded Steel Fittings - Pressure Classes vs. Schedules
Pressure classes, schedules and weights of pipes for threaded & socket welded fittings.
Vacuum Pumps - Exhaust Pipe Capacities
Capacities of vacuum pump exhaust pipes.
