Steel Pipes - Bundling Schedules Length and Weight
Bundling schedules for standard weight and extra strong pipes:
Nominal Pipe Size
(in)
No. Pieces per BundleStandard Weight PipeExtra Strong Pipe
Total Length
(ft)
Total Weight
(lb)
Total Length
(ft)
Total Weight
(lb)
1/8 30 630 151 630 195
1/4 24 504 212 504 272
3/8 18 378 215 378 280
1/2 12 252 214 252 275
3/4 7 147 166 147 216
1 5 105 176 105 228
1 1/4 3 63 144 63 189
1 1/2 3 63 172 63 229
  • 1 ft = 0.3048 m
  • 1 lb = 0.4536 kg
Dimensions of Pipes and Tubes
ANSI Steel Pipe Schedule 40 Chart: Dimensions, Weights & Specifications
ASME/ANSI B36.10/19 - Carbon, Alloy and Stainless Steel Pipe - Dimensions
ASTM A53 B Carbon Steel Pipes - Allowable Pressure vs. Schedule and Size
Maximum working pressure of carbon steel pipe at temperature 400oF.
ASTM International - Standards for Steel Pipes, Tubes and Fittings
The ASTM standards covers various types of steel pipes, tubes and fittings for high-temperature services, ordinary use and special applications such as fire protection use
Carbon Steel Pipes - Pressure and Temperature Ratings, Imperial Units
Pressure (psig) and temperature (deg F) ratings for A-53 B and A-106 B, A333, A334 and API 5L carbon steel pipes - temperatures ranging 100 degF - 700 degF.
Pipes - Nominal Wall Thickness
Nominal wall thickness of seamless and welded carbon and alloy steel pipes
Schedule - Terminology
Introduction to the schedule terminology of pipes.
Stainless Steel Pipes - Allowable Pressure vs. Schedule and Size
Allowable pressure for standard seamless A312-TP316/316L stainless steel pipes - temperatures 100oF to 750oF.
Steel Pipes - Heat Loss Diagram
Heat loss from steel pipes and tubes - dimensions 1/2 to 12 inches.
Steel Pipes - Maximum Water Flow Capacities vs. Size
Maximum water flow capacities in steel pipes - pipe dimensions ranging 2 - 24 inches.
Steel Pipes - Weight
Steel Pipes Schedule 40 - Pressure Loss
Water flow and pressure loss in schedule 40 steel pipes - Imperial and SI units - gallons per minute, liters per second and cubic meters per hour.
