The maximum and minimum length of a pipe depends to the maximum and minimum temperature of the pipe - in cold (non operating) and running (operating) condition. The temperature expansion coefficient steel pipes per degree change of temperature is nearly constant:
  • 6.5 10-6 (in/in oF)
  • 14.0 10-6 (m/m oC)
Carbon Steel Pipes - Temperature Expansion - Fahrenheit
The temperature expansion of carbon steel pipes expressed in inches per 100 feet per degree Fahrenheit:
Carbon Steel Pipes - Temperature Expansion - Celcius
The temperature expansion of carbon steel pipes expressed in mm per m per degree Celsius:
Example - Expansion of Steam Pipe
The expansion of 10 m steam pipe from an installation temperature of 20 oC to design temperature 180 oC (pressure 10 bar) is 2.4 mm/m or
10 (m) 2.4 (mm/m) = 24 mm
Piping Systems
Thermal expansion of pipes and tubes - stainless steel, carbon steel, copper, plastics and more.
Calculate ring (or pipe) diameter expansion or contraction when temperature changes.
Linear Thermal Expansion
Liquids and Fluids - Specific Heats
Piping Materials - Temperature Heat Expansion and Cooling Contraction
Expansion and contraction when cast iron, carbon and carbon molybdenum steel, wrought iron, copper, brass and aluminum pipes are heated or cooled.
Shrink-Fits Assembly
Assembly temperatures for shrink-fits.
Specific Heat of common Substances
Steam Pipes - Thermal Expansion
Thermal expansion of steam pipes heated from room temperature to operation temperature (mm pr. 100 m pipe).
Steel Pipes - Bundling Schedules Length and Weight
Bundling schedules for standard weight and extra strong steel pipes.
Steel Pipes - Thermal Expansion Loops
Calculating and sizing steel pipe thermal expansion loops.
Steel Pipes - Weight
Thermal Expansion - Linear Expansion Coefficients
Linear temperature expansion coefficients for common materials like aluminum, copper, glass, iron and many more.
Thermal Expansion of Steam Pipes - (inches)
Expansion of steam pipes heated from room temperature to operation temperature.
