The temperature expansion of pipes depends on start and final temperature of the pipe, and the expansion coefficient of the piping material at the actual temperature. The expansion formula can be expressed as:
dl = α Lo dt                            (1)
dl = expansion (m, inches)
Lo = length of pipe (m, inches)
dt = temperature difference (oC, oF)
α = linear expansion coefficient (m/moK, in/inoF)
Note that the mean expansion coefficient may vary with temperature:
MaterialMean Expansion Coefficient  10-6 (in/in oF,
Temperature Range (oF)
- 3232 - 21232 - 40032 - 60032 - 75032 - 90032 - 110032 - 1300
Alloy Steel
(1% Cr. 1/2% Mo)
7.7 8.0 8.4 8.8 9.2 9.6 9.8
Mild Steel
(0.1 - 0.2% C)
7.1 7.8 8.3 8.7 9.0 9.5 9.7
Stainless Steel
(18% Cr. 8% Ni)
10.8 11.1 11.5 11.8 12.1 12.4 12.6 12.8
Formula (1) can also be used with SI units. The expansion coefficient must be adjusted to oC.
Example - Thermal Expansion of an Alloy Steel Pipe
An alloy steel pipe with length 100 feet is heated from 32 to 211 oF. The expansion coefficient is 8×10-6 (in/inoF).
The expansion of the pipe can be calculated as:
dl = (8×10-6 in/inoF) (100 ft) (12 in/ft) ((212 oF) - (32 oF))
    = 1.728 inches
Piping Systems
Sizing of Steam and Condensate Pipes
Dimensions of steam and condensate pipe lines. Calculate pressure losses, recommended velocities, capacities and more.
Calculate ring (or pipe) diameter expansion or contraction when temperature changes.
Copper Tubes - Expansion Loop Capacity
Capacity of copper tubes expansion loops.
Linear Thermal Expansion Coefficients of Materials
Linear thermal expansion coefficients of common materials, including metals, plastics, and composites.
Linear Thermal Expansion: Formula, Coefficients & Calculator
Piping Elbows - Thrust Block Forces
Thrust block forces on pipe bends anchors due to liquid velocities and internal pressures - online resulting force calculator.
Piping Materials - Temperature Heat Expansion and Cooling Contraction
Expansion and contraction when cast iron, carbon and carbon molybdenum steel, wrought iron, copper, brass and aluminum pipes are heated or cooled.
Steam Pipes - Thermal Expansion
Thermal expansion of steam pipes heated from room temperature to operation temperature (mm pr. 100 m pipe).
Steel Pipes Expansion Loops - Design and Calculation
Steel pipe expansion loops and their importance in managing thermal expansion, and how to design and size them effectively. Key considerations, calculations, and installation tips to prevent stress and damage in piping systems.
Thermal Expansion of Steam Pipes - (inches)
Expansion of steam pipes heated from room temperature to operation temperature.
Threaded Rods - Proof Loads - Metric Units
Proof load capacities of metric threaded steel rods.
