Temperature
(oF)
Note! - to avoid unacceptable stress and damage in a steam pipe line - handle expansion properly.
A system is designed for pressure 120 psi with operating temperature 350 oF. As indicated in the table above (350 oF) the expansion is is approximately 2.4 in100ft pipe.
The expansion of a 90 ft long pipe can be calculated as
dl = ((2.4 in100ft) / (100 ft)) (90 ft)
= 2.2 in
Sizing of steam and condensate pipe lines - pressure loss, recommended velocity, capacity and more.
Calculate ring (or pipe) diameter expansion or contraction when temperature changes.
Expansion and contraction when cast iron, carbon and carbon molybdenum steel, wrought iron, copper, brass and aluminum pipes are heated or cooled.
Steam is a compressible gas where pipe line mass flow capacity depends on steam pressure.
Sizing of steam pipe lines - major and minor loss in steam distribution systems.
Thermal expansion of steam pipes heated from room temperature to operation temperature (mm pr. 100 m pipe).
Calculating and sizing steel pipe thermal expansion loops.
Linear temperature expansion coefficients for common materials like aluminum, copper, glass, iron and many more.
