The linear thermal expansion coefficient is the ratio change in length per degree temperature to length.
Linear thermal expansion for some common metals:
| Metal | Temperature Range (oF) | Thermal Expansion (10-6 in/(in oF)) |
| Admiralty Brass | 68 - 572 | 11.2 |
| Aluminum | 68 - 212 | 13.1 |
| Aluminum Bronze | 68 - 572 | 9.0 |
| Aluminum Alloy - 2011 | 12.8 | |
| Aluminum Alloy - 2017 | 13.1 | |
| Aluminum Alloy - 2024 | 12.9 | |
| Aluminum Alloy - 3003 | 12.9 | |
| Aluminum Alloy - 5052 | 13.2 | |
| Aluminum Alloy - 5086 | 13.2 | |
| Aluminum Alloy - 6061 | 13.0 | |
| Aluminum Alloy - 7075 | 13.1 | |
| Antimony | 5 | |
| Beryllium | 6.7 | |
| Beryllium Copper | 68 - 212 | 9.3 |
| Bismuth | 7.2 | |
| Cast Iron, grey | 32 - 212 | 5.8 |
| Cast Steel, 3% C |
7.0 |
| Chromium | 3.3 | |
| Cobalt | 6.7 | |
| Copper | 68 - 572 | 9.8 |
| Copper-Base Alloy - Manganese Bronze | 11.8 | |
| Copper-Base Alloy - C1100 (Electrolytic tough pitch) | 9.8 | |
| Copper-Base Alloy - C14500 (Free Machining Cu) | 9.9 | |
| Copper-Base Alloy - C17200, C17300 (Beryllium Cu) | 9.9 | |
| Copper-Base Alloy - C18200 (Chromium Cu) | 9.8 | |
| Copper-Base Alloy - C18700 (Leaded Cu) | 9.8 | |
| Copper-Base Alloy - C22000 (Commercial bronze, 90%) | 10.2 | |
| Copper-Base Alloy - C23000 (Red brass, 85%) | 10.4 | |
| Copper-Base Alloy - C26000 (Cartridge brass, 70%) | 11.1 | |
| Copper-Base Alloy - C27000 (Yellow brass) | 11.3 | |
| Copper-Base Alloy - C28000 (Muntz metal, 60%) | 11.6 | |
| Copper-Base Alloy - C33000 (Low-leaded brass tube) | 11.2 | |
| Copper-Base Alloy - C35300 (High-leaded brass) | 11.3 | |
| Copper-Base Alloy - C35600 (Extra high-leaded brass) | 11.4 | |
| Copper-Base Alloy - C36000 (Free machining brass) | 11.4 | |
| Copper-Base Alloy - C36500 (Leaded Muntz metal) | 11.6 | |
| Copper-Base Alloy - C46400 (Naval brass) | 11.8 | |
| Copper-Base Alloy - C51000 (Phosphor bronze, 5% A) | 9.9 | |
| Copper-Base Alloy - C54400 (Free cutting phos. bronze) | 9.6 | |
| Copper-Base Alloy - C62300 (Aluminum bronze, 9%) | 9.0 | |
| Copper-Base Alloy - C62400 (Aluminum bronze, 11%) | 9.2 | |
| Copper-Base Alloy - C63000 (Ni-Al bronze) | 9.0 | |
| Copper-Base Alloy - Nickel-Silver | 9.0 | |
| Cupronickel | 68 - 572 | 9.0 |
| Ductile Iron, A536 (120-90-02) | 5.9 - 6.2 | |
| Gold | 7.9 | |
| Hastelloy C | 70 - 200 | 5.3 |
| Inconel | 68 - 212 | 6.4 |
| Incoloy | 32 - 212 | 8.0 |
| Invar | 68 - 212 | 0.67 |
| Iridium | 3.3 | |
| Iron, nodular pearlitic | 68 - 212 | 6.5 |
| Iron, pure | 68 - 212 | 6.8 |
| Kovar | 77 - 392 | 3.05 |
| Kovar | 77 - 572 | 2.83 |
| Kovar | 77 - 752 | 2.72 |
| Kovar | 77 - 932 | 3.44 |
| Magnesium | 14 | |
| Malleable Iron, A220 (50005, 60004, 80002) | 7.5 | |
| Manganese | 12 | |
| Manganese Bronze | 68 - 572 | 11.8 |
| Mild steel | 5.9 | |
| Molybdenum | 3.0 | |
| Monel | 32 - 212 | 7.8 |
| Nickel-Base Alloy - Nickel 200, 201, 205 | 8.5 | |
| Nickel-Base Alloy - Hastelloy C-22 | 6.9 | |
| Nickel-Base Alloy - Hastelloy C-276 | 6.2 | |
| Nickel-Base Alloy - Inconel 718 | 7.2 | |
| Nickel-Base Alloy - Monel | 8.7 | |
| Nickel-Base Alloy - Monel 400 | 7.7 | |
| Nickel-Base Alloy - K500 | 7.6 | |
| Nickel-Base Alloy - R405 | 7.6 | |
| Nickel Wrought | 77 - 212 | 7.4 |
| Niobium (Columbium) | 3.9 | |
| Red Brass | 68 - 572 | 10.4 |
| Osmium | 2.8 | |
| Platinum | 5 | |
| Plutonium | 19.84 | |
| Potassium | 46 | |
| Rhodium | 4.4 | |
| Selenium | 21 | |
| Silicon | 2.8 | |
| Silver | 11 | |
| Sodium | 39 | |
| Stainless Steel - S30100 | 9.4 | |
| Stainless Steel - S30200, S30300, S30323 | 9.6 | |
| Stainless Steel - S30215 | 9.0 | |
| Stainless Steel - S30400, S30500 | 9.6 | |
| Stainless Steel - S30430 | 9.6 | |
| Stainless Steel - S30800 | 9.6 | |
| Stainless Steel - S30900, S30908 | 8.3 | |
| Stainless Steel - S31000, S31008 | 8.8 | |
| Stainless Steel - S31600, S31700 | 8.8 | |
| Stainless Steel - S31703 | 9.2 | |
| Stainless Steel - S32100 | 9.2 | |
| Stainless Steel - S34700 | 9.2 | |
| Stainless Steel - S34800 | 9.3 | |
| Stainless Steel - S38400 | 9.6 | |
| Stainless Steel - S40300, S41000, S41600, 41623 | 5.5 | |
| Stainless Steel - S40500 | 6.0 | |
| Stainless Steel - S41400 | 5.8 | |
| Stainless Steel - S42000, S42020 | 5.7 | |
| Stainless Steel - S42200 | 6.2 | |
| Stainless Steel - S42900 | 5.7 | |
| Stainless Steel - S43000, S43020, S43023 | 5.8 | |
| Stainless Steel - S43600 | 5.2 | |
| Stainless Steel - S44002, S44004 | 5.7 | |
| Stainless Steel - S44003 | 5.6 | |
| Stainless Steel - S44600 | 5.8 | |
| Stainless Steel - S50100, S50200 | 6.2 | |
| Tantalum | 3.6 | |
| Thorium | 6.7 | |
| Tin | 32 - 212 | 12.8 |
| Titanium | 68 - 200 | 4.8 |
| Titanium Alloy - Ti-5Al-2.5Sn | 5.3 | |
| Ti-8Mn | 6.0 | |
| Tungsten | 2.5 | |
| Uranium | 7.4 | |
| Vanadium | 4.4 | |
| Wrought Carbon Steel | 70 - 800 | 7.8 |
| Yellow Brass | 68 - 572 | 11.3 |
| Zinc | 19 |
- T (oC) = 5/9 (T (oF) - 32)
- 1 in (inch) = 25.4 mm
- 1 ft (foot) = 0.3048 m
Note that the coefficient of expansions may change with temperature.
• Temperature Expansion
Aluminum - Thermophysical Properties
Density, specific heat and thermal conductivity related to temperature.
Beryllium - Specific Heat vs. Temperatures
Specific heat of beryllium related to temperature.
Bimetallic Strips
Heat and bending of bimetallic strips.
Chromium - Specific Heat and Thermal Conductivities vs. Temperatures
Specific heat and thermal conductivity of chromium related to temperature.
Calculate ring (or pipe) diameter expansion or contraction when temperature changes.
Iron - Density, Specific Heats and Thermal Conductivities vs. Temperatures
Specific heat, density and thermal conductivity of iron related to temperature.
Linear Thermal Expansion Coefficients of Materials
Linear thermal expansion coefficients of common materials, including metals, plastics, and composites.
Linear Thermal Expansion: Formula, Coefficients & Calculator
Malleability vs. Brittlenes vs. Ductility
Plastic deformation properties.
Metal Alloys - Specific Heats
Specific heat of metal alloys like brass, bronze and more.
Metals - Boiling Temperatures
Metals and their boiling temperatures.
Metals - Latent Heat of Melting
Metals and their latent heat of fusion.
Shrink-Fits Assembly
Assembly temperatures for shrink-fits.
Solids - Volume Temperature Expansion Coefficients
Cubical expansion coefficients for solids.
Stainless Steel - Specific Heat and Thermal Conductivities vs. Temperatures
Specific heat and thermal conductivity of stainless steel vs. temperature
Steam Pipes - Thermal Expansion
Thermal expansion of steam pipes heated from room temperature to operation temperature (mm pr. 100 m pipe).
Steel Pipes Expansion Loops - Design and Calculation
Steel pipe expansion loops and their importance in managing thermal expansion, and how to design and size them effectively. Key considerations, calculations, and installation tips to prevent stress and damage in piping systems.
Thermal Expansion - Superficial i.e. Area
Superficial i.e area temperature expansion - online calculator.
Thermal Expansion of Steam Pipes - (inches)
Expansion of steam pipes heated from room temperature to operation temperature.
