Chromium - Specific Heat and Thermal Conductivities vs. Temperatures
T
(K)
c
(kJ/kg K)
k
(W/m K)
100 0.192 159
200 0.384 111
300 0.449 93.7
400 0.484 90.9
600 0.542 80.7
800 0.581 71.3
1000 0.616 65.4
1200 0.682 61.9
1500 0.779 57.2
2000 0.937 49.4
Material Properties
AISI/SAE Steel and Alloys - Designation System
The AISI/SAE carbon steel and alloys naming conventions.
Metals - Specific Heats
Metals and Alloys - Densities
Metals, Metallic Elements and Alloys - Thermal Conductivities
Thermal conductivities of common metals, metallic elements aand alloys.
Nickel-Chromium Heater Wire - Temperature Rise vs. Amps
Electric resistance vs. temperature rise for Nickel-Chromium electrical heater wire.
Resistivity and Conductivity - Temperature Coefficients Common Materials
Resistivity, conductivity and temperature coefficients for common materials like silver, gold, platinum, iron and more..
