Nickel-Chromium Heater Wire - Temperature Rise vs. Amps
Nickel-Chromium electric resistance wires:
SWG | Diameter | Nickel–chromium | |||
(mm) | (in) | (ohm/m) | Current (A) to maintain temperature rise | ||
500 °C | 1000 °C | ||||
12 | 2.642 | 0.104 | 0.197 | 38 | 78 |
14 | 2.032 | 0.080 | 0.333 | 26 | 53 |
16 | 1.626 | 0.064 | 0.520 | 19 | 40 |
18 | 1.219 | 0.048 | 0.92 | 13 | 27 |
20 | 0.914 | 0.036 | 1.65 | 8.5 | 18 |
22 | 0.711 | 0.028 | 2.72 | 6.3 | 13 |
24 | 0.559 | 0.022 | 4.40 | 4.5 | 9.5 |
26 | 0.457 | 0.018 | 6.60 | 3.5 | 7.0 |
28 | 0.376 | 0.0148 | 9.7 | 2.7 | 5.5 |
30 | 0.315 | 0.0124 | 13.9 | 2.2 | 4.5 |
32 | 0.274 | 0.0108 | 18.3 | 1.9 | 3.5 |
34 | 0.234 | 0.0092 | 25.2 | 1.6 | 3.0 |
36 | 0.193 | 0.0076 | 37.0 | 1.3 | 2.3 |
38 | 0.152 | 0.0060 | 59.0 | 1.0 | 1.7 |
40 | 0.122 | 0.0048 | 92 | 0.8 | 1.4 |
42 | 0.102 | 0.0040 | 133 | 0.65 | 1.1 |
44 | 0.0813 | 0.0032 | 208 | ||
46 | 0.0610 | 0.0024 | 370 | ||
48 | 0.0406 | 0.0016 | 835 | ||
50 | 0.0254 | 0.0010 | 2130 |
- SWG - Imperial Standard Wire Gauge for sheet metal and wire
Example - Electric heater
Calculate the length of a nickel-chromium gauge 18 wire in an electric heater with power 2000 W, 230 V supply and max. wire temperature 500 oC.
The current required to produce 2000 W can be calculated with Ohm's law as
P = U I (1)
or
I = P / U (2)
= (2000 W) / (230V)
= 8.7 A
The max. current in the 18 gauge wire with max. temperature 500 oC is 13 A and the heat can be produced in a single wire.
The total resistance in the heating wire can with Ohm's law be calculated as
R = U / I (3)
= (230 V) / (8.7 A)
= 26.4 ohm
Since the resistance of the wire is 0.92 ohm/m the length of the wire can be calculated as
l = (26.4 ohm) / (0.92 ohm/m)
= 28.7 m
• Electrical
AWG Wire Gauge Chart & Table – American Wire Gauge (AWG) Standards
The AWG (American Wire Gauge) wire size chart with detailed specifications on wire diameter, resistance, and ampacity. Find conversions between AWG sizes and metric units for electrical and engineering applications.
Chromium - Specific Heat and Thermal Conductivities vs. Temperatures
Specific heat and thermal conductivity of chromium related to temperature.
Copper Wire - Electrical Resistance vs. Gauge
Gauge, weight, circular mils and electrical resistance in copper wire.
Electric Wire - Resistance
Electric resistance in wire made of Copper, Aluminum, Brass, Constantan, Nichrome, Platinum, Silver or Tungsten.
Ohm's Law
The relation between voltage, current and electrical resistance.
Resistance vs. Resistivity
Electrical resistance and resistivity.
SWG - Standard Wire Gauge
Imperial Standard Wire Gauge used with wire and sheet metal.
