Electric Wire - Resistance
Electric resistance in
- Aluminum
- Brass
- Constantan
- Copper
- Nichrome
- Platinum
- Silver
- Tungsten
wire at 20 oC.
AWG Gauge
Download and print Electrical Wire Resistance chart
Diameter (mm)
Square Area (mm2)
• Electrical
12 Volt - Electric Automotive Wiring
Maximum wire lengths vs. currents in the 12 volt electrical system of a car.
12 Volt - Maximum Wire Length vs. Current
Maximum length of copper wire with 2% voltage drop.
12 Volt - Wire Gauge vs. Amps
Maximum current (amps) in a 12V electrical circuit vs. size (AWG) and length of wire.
Aluminum and Copper Wires - Electrical Resistance vs. Cross-Sectional Area
Electrical resistance in plain copper or aluminum wires.
Aluminum Conductor Characteristics
Characteristics of all-aluminum conductors (AAC).
AWG - American Wire Gauge Converting Chart
American Wire Gauge (AWG) vs. cross sectional area converter.
AWG - American Wire Gauge vs. Circular Mils
AWG vs. diameter mil, circular mil, diameter in mm and area in mm2.
Copper Wire - Electrical Resistance vs. Gauge
Gauge, weight, circular mils and electrical resistance in copper wire.
Electric Motors - 480 Volt Wiring
480V electrical motor wiring data - NEMA amps, starter size, HMCP size for motors ranging 1/2 to 500 hp.
Electric Wire - Calculating Cross-Section Areas
Calculate single and bunched electric wire cross-section area and diameter.
Electric Wire - Maximum Length with 240 Volts Single-Phase Power
Maximum length of 240 V single phase electric wire with max. 2% voltage drop.
Electrical Conductivity - Elements and other Materials
Electric conductance is the ability of a element to conduct an electric current.
Nickel-Chromium Heater Wire - Temperature Rise vs. Amps
Electric resistance vs. temperature rise for Nickel-Chromium electrical heater wire.
Resistance vs. Conductance
The reciprocal of electrical resistance is conductance.
Resistance vs. Resistivity
Electrical resistance and resistivity.
Resistivity and Conductivity - Temperature Coefficients Common Materials
Resistivity, conductivity and temperature coefficients for common materials like silver, gold, platinum, iron and more..
SWG - Standard Wire Gauge
Imperial Standard Wire Gauge used with wire and sheet metal.
