Electrical Resistance vs. Conductance
The unit of electric resistance is ohm (Ω)
R = U / I (1)
R = resistance (ohm, Ω)
U = electrical potential (volts)
I = current flow (ampere)
The reciprocal of resistance is conductance
G = 1 / R (2)
G = conductance (siemens, S)
Example - Conductance
Conductance of a conductor with resistance 10 Ω can be calculated as
G = 1 / ( 10 Ω)
= 0.1 siemens, S
• Electrical
Aluminum and Copper Wires - Electrical Resistance vs. Cross-Sectional Area
Electrical resistance in plain copper or aluminum wires.
Aluminum Conductor Characteristics
Characteristics of all-aluminum conductors (AAC).
Copper Wire - Electrical Resistance vs. Gauge
Gauge, weight, circular mils and electrical resistance in copper wire.
Electric Wire - Resistance
Electric resistance in wire made of Copper, Aluminum, Brass, Constantan, Nichrome, Platinum, Silver or Tungsten.
Electrical Formulas
Commonly used electrical formulas like Ohms Law and more.
Ohm's Law
The relation between voltage, current and electrical resistance.
Resistivity and Conductivity - Temperature Coefficients Common Materials
Resistivity, conductivity and temperature coefficients for common materials like silver, gold, platinum, iron and more..
Resistors - Color Codes Calculator
Color codes for fixed resistors - values and tolerances - online calculator.
