Resistors - Color Codes Calculator
Color codes for fixed resistors:
ColorSignificant
Figures
MultiplierTolerance
Silver 10-2 +/- 10%
Gold 10-1 +/- 5%
Black 0 1
Brown 1 10 +/- 1%
Red 2 102 +/- 2%
Orange 3 103
Yellow 4 104
Green 5 105 +/- 0.5%
Blue 6 106 +/- 0.25%
Violet 7 107 +/- 0.1%
Grey 8 108
White 9 109
None +/- 20%
Four Band Fixed Resistor
Two first bands (first band is the one nearest the end of the resistor) indicates the value, the third indicates the multiplier and the fourth indicates tolerance.
Example - Value Four Band Fixed Resistor
A resistor with the four color bands
yellow - violet - orange - red
    4   -    7    -  103   -   +/-2%
has a value of 47 kΩ with tolerance +/- 2%.
Four Band Resistor Calculator
Band 1 Band 2 Multiplier Tolerance
Download and print Resistors - Standard Colors Codes table
Five Band Fixed Resistor
Three first bands (first band is the one nearest the end of the resistor) indicates the value, the fourth indicates the multiplier and the fifth indicates tolerance.
Example - Value Five Band Fixed Resistor
A resistor with the five color bands
red - yellow - white - orange - brown
 2   -    4     -   9    -  103   -    +/-1%
has a value of 249 kΩ with tolerance +/- 1%.
Five Band Resistor Calculator
Band 1 Band 2 Band 3 Multiplier Tolerance
Electrical
Aluminum and Copper Wires - Electrical Resistance vs. Cross-Sectional Area
Electrical resistance in plain copper or aluminum wires.
Electrical Formulas
Commonly used electrical formulas like Ohms Law and more.
Electrical Parallel Circuits
Electrical Resistance in Serial and Parallel Networks
Resistors in parallel and serial connections.
Electrical Resistance vs. Conductance
The reciprocal of electrical resistance is conductance.
Ohm's Law
The relation between voltage, current and electrical resistance.
Resistivity and Conductivity - Temperature Coefficients Common Materials
Resistivity, conductivity and temperature coefficients for common materials like silver, gold, platinum, iron and more..
Resistor Standard Values
Preferred number series for resistors.
Resistors - Letters and Digit Codes
Letter and digit codes to indicating resistor values.
