Resistors - Letters and Digit Codes
Values of resistors can be indicated with letters and digit codes:
Value | Mark |
0.47 Ω | R47 |
1 Ω | 1R0 |
4.7 Ω | 4R7 |
47 Ω | 47R |
100 Ω | 100R |
1 kΩ | 1K0 |
1 MΩ | 1M |
Tolerance is indicated as
F = +- 1%
G = +- 2%
J = +- 5%
K = +- 10%
M = +- 20%
Example - Resistor with letter and digit code
4R7K = 4.7 Ω +- 10%
• Electrical
Electrical Parallel Circuits
Electrical Resistance in Serial and Parallel Networks
Resistors in parallel and serial connections.
Resistor Standard Values
Preferred number series for resistors.
Resistors - Color Codes Calculator
Color codes for fixed resistors - values and tolerances - online calculator.
