Resistor Standard Values
Preferred number series for resistors according IEC 60063 are indicated below.
Resistors with 20% tolerance
Resistors and their color coding:
Download and print Resistors - Standard Colors Codes table
Resistors with 10% tolerance
ohm | kohm | ||||
10 | 100 | 1 | 10 | 100 | .. |
12 | 120 | 1.2 | 12 | 120 | .. |
15 | 150 | 1.5 | 15 | 150 | .. |
18 | 180 | 1.8 | 18 | 180 | .. |
22 | 220 | 2.2 | 22 | 220 | .. |
27 | 270 | 2.7 | 27 | 270 | .. |
33 | 330 | 3.3 | 33 | 330 | .. |
39 | 390 | 3.9 | 39 | 390 | .. |
47 | 470 | 4.7 | 47 | 470 | .. |
56 | 560 | 5.6 | 56 | 560 | .. |
68 | 680 | 6.8 | 68 | 680 | .. |
82 | 820 | 8.2 | 82 | 820 | .. |
Resistors with 5% tolerance
ohm | kohm | ||||
10 | 100 | 1.0 | 10 | 100 | .. |
11 | 110 | 1.1 | 11 | 110 | |
13 | 130 | .1.3 | 13 | 130 | |
16 | 160 | 1.6 | 16 | 160 | |
20 | 200 | 2.0 | 20 | 200 | |
24 | 240 | 2.4 | 24 | 240 | |
30 | 300 | 3.0 | 30 | 300 | |
36 | 360 | 3.6 | 36 | 360 | |
43 | 430 | 4.3 | 43 | 430 | |
51 | 510 | 5.1 | 51 | 510 | |
62 | 620 | 6.2 | 62 | 620 | |
75 | 750 | 7.5 | 75 | 750 | |
91 | 910 | 9.1 | 91 | 910 |
Equivalent Expressions of Ohm's Law
Ohm's law can be expressed as
U = R I (1)
or
R = U / I (2)
• Electrical
Aluminum and Copper Wires - Electrical Resistance vs. Cross-Sectional Area
Electrical resistance in plain copper or aluminum wires.
Electrical Parallel Circuits
Electrical Resistance in Serial and Parallel Networks
Resistors in parallel and serial connections.
Ohm's Law
The relation between voltage, current and electrical resistance.
Resistors - Color Codes Calculator
Color codes for fixed resistors - values and tolerances - online calculator.
Resistors - Letters and Digit Codes
Letter and digit codes to indicating resistor values.
