Electrical Resistance in Serial and Parallel Networks
Serial Connection
The total resistance for resistors connected in series can be calculated as
R = R1 + R2 + .... + Rn                   (1)
R = resistance (ohm, Ω)
Example - Resistors in Series
Three resistors 33 ohm , 33 ohm and 47 ohm are connected in serial. The total resistance can be calculated as
R = (33 ohm) + (33 ohm) + (47 ohm)
= 113 ohm
Standard resistors are available with
  • resistances from 0.0002 Ω through 1012 Ω
  • power ratings from 1/8 watt through 250 watts
  • accuracies from 0.005% through 20%
Parallel Connection
The total resistance for resistors connected in parallel can be calculated as
1 / R = 1 / R1 + 1 / R2 + .... + 1 / Rn               (2)
Equivalent resistance of 2 resistors connected in parallel can be expressed as
R = R1 R2 / (R1 + R2)          (3)
Example - Resistors in Parallel
Three resistors 33 ohm , 33 ohm and 47 ohm are connected in parallel. The total resistance can be calculated as
1 / R = 1 / (33 ohm) + 1 / (33 ohm) + 1 / (47 ohm)
= 0.082 (1 / ohm)
R = 1 / (0.082 ohm)
= 12.2 ohm
If the battery voltage is 12 V - the current through the circuit can be calculated by using Ohm's law
I = U / R
= (12 V) / (12.2 ohm)
= 0.98 ampere
The current through each resistor can be calculated
I1 = U / R1 = (12 V) / (33 ohm) = 0.36 ampere
I2= U / R2= (12 V) / (33 ohm) = 0.36 ampere
I3 = U / R3 = (12 V) / (47 ohm) = 0.26 ampere
Resistors Connected in Parallel - Calculator
Add the resistances for up to five parallel connected resistors and (optionally) the circuit voltage.
The total resistance and current - and the individual currents in all resistors - will be calculated:
Power Dissipated by a Resistor
The power dissipated by a resistor can be expressed as
P = U I
   = R I2
   = U2 / R          (4)
P = power (W, Js)
Thévenin Equivalent Circuit
Thévenin’s theorem states that
  • any two-terminal network of resistors and voltage sources is equivalent to a single resistor R in series with a single voltage source V.
The voltage divider can be regarded as a Thévenin Equivalent Circuit where the internal arrangement of resistors and the input voltage source equivalents so a single source and a single resistor.
Electrical
Aluminum Conductor Characteristics
Characteristics of all-aluminum conductors (AAC).
Capacitors
Capacitors and capacitance - charge and unit of charge.
Capacitors - Parallel and Serial Circuits
Parallel and serial connected capacitor circuits.
Current Divider - Online Calculator
An electric current divider outputs a current that is a fraction of the input current.
Electrical Inductance - Serial and Parallel Connections
Electrical inductance in serial and parallel connected inductors.
Electrical Parallel Circuits
Electrical Series Circuits
Voltage and current in electrical series circuits.
Lead-Acid Batteries
Specific gravity and charge of lead acid batteries - temperature and efficiency.
Resistor Standard Values
Preferred number series for resistors.
Resistors - Color Codes Calculator
Color codes for fixed resistors - values and tolerances - online calculator.
Resistors - Letters and Digit Codes
Letter and digit codes to indicating resistor values.
Voltage Dividers - Online Calculator
Output voltage potential divider.
