Potential Divider - Online Calculator
A potential divider is the simplest way of producing a source of lower e.m.f. from a source of higher e.m.f.
The output voltage from a potential divider can be calculated as
Uout = Uin R2 / (R1 + R2)                 (1)
Uout = output voltage (V)
R = resistance (Ohms, Ω)
Uin = input voltage (V)
Example - Potential Divider - High Power Consumption
The output voltage from a potential divider with two resistors R1 = 10 ohms and R2 = 20 ohms and input voltage 12 V can be calculated as
     Uout = (12 V) (20 Ω) / ((10 Ω) + (20 Ω))
        = 8 (V)
The current through the potential divider R1 and R2 (ex. output current) can be calculated by using Ohm's law
I = U / R
  = (12 V) / ((10 Ω) + (20 Ω))
  = 0.4 A
The power consumption of the divider can be calculated
P = U I
   = (12 V) (0.4 A)
   = 4.8 W
Example - Potential Divider - Lower Power Consumption
The output voltage from a potential divider with two resistors R1 = 1000 ohms and R2 = 2000 ohms and input voltage 12 V can be calculated as
     Uout = (12 V) (2000 Ω) / ((1000 Ω) + (2000 Ω))
        = 8 (V)
I = U / R
  = (12 V) / ((1000 Ω) + (2000 Ω))
  = 0.004 A
P = U I
   = (12 V) (0.004 A)
   = 0.048 W
The power consumption in a potential divider can be reduced by increased resistance.
Potential Divider - Calculator
Potential Divider Nomogram
The nomogram below can be used to estimate a potential divider.
  Download and print the Potential Divider Nomogram!
The default values in the nomogram abocve are for Uin = 12 VR2 = 47 ohm and Uout3.3 V. Since the sum of the resistances (R1 + R2) according the nomogram is approximately 170 ohm - the resistance R1 can be calculated as
R1 ≈ (170 ohm - 47 ohm)
    ≈ 123 ohm.
Electrical
Electrical units, amps and electrical wiring, wire gauge and AWG, electrical formulas and motors.
Current Divider - Online Calculator
An electric current divider outputs a current that is a fraction of the input current.
Electrical Conductivity - Elements and other Materials
Electric conductance is the ability of a element to conduct an electric current.
Electrical Parallel Circuits
Electrical Resistance in Serial and Parallel Networks
Resistors in parallel and serial connections.
Electrical Series Circuits
Voltage and current in electrical series circuits.
Electromotive Force - e.m.f
Change in electrical potential between two points.
Kirchhoff's Voltage and Current Laws
Kirchhoff's current and voltage laws.
Resistance vs. Resistivity
Electrical resistance and resistivity.
