Resistance vs. Resistivity
Electrical resistance of an electrical conductor depends on
- the length of the conductor
- the material of the conductor
- the temperature of the material
- the cross-sectional area of the conductor
Electrical resistance of a conductor can be calculated as
R = ρ L / A
= L / (σ A) (1)
R = resistance of the conductor (ohms, Ω)
ρ = resistivity of the conductor material (ohm metre, Ω m)
σ = electrical conductivity (1/ohms m, 1/Ω m, siemens/m, S/m, mho/m)
L = length of conductor (m)
A = cross-sectional area of conductor (m2)
Resistivity of some Common Conductors
- Aluminum: 2.65×10-8 Ω m (0.0265 μΩ m)
- Carbon: 10×10-8 Ω m (0.10 μΩ m)
- Copper: 1.724×10-8 Ω m (0.0174 μΩ m)
- Iron: 10×10-8 Ω m (0.1 μΩ m)
- Silver: 1.6×10-8 Ω m (0.0265 μΩ m)
Note that resistivity depends on temperature . The values above are for temperatures 20 oC .
Resistivity of some Common Insulators
- bakelite: 1×1012 Ω m
- glass: 1×1010 - 1×1011 Ω m
- marble: 1×108 Ω m
- mica: 0.9 ×1013 Ω m
- paraffin oil: 1×1016 Ω m
- paraffin wax (pure) : 1×1016 Ω m
- plexiglass: 1×1013 Ω m
- polystyrene: 1×1014 Ω m
- porcelain: 1×1012 Ω m
- pressed amber: 1×1016 Ω m
- vulcanite: 1×1014 Ω m
- water, distilled: 1×1010 Ω m
Note that good conductors of electricity have low resistivity and good insulators have high resistivity.
Example - Resistance of a Conductor
The resistance of 10 meter gauge 17 copper wire with cross sectional area 1.04 mm2 can be calculated as
R = (1.7×10-8 Ω m) (10 m) / ((1.04 mm2)(10-6 m2/mm2))
= 0.16 Ω
Example - Cross-sectional area and Resistance
The copper wire above is reduced to gauge 24 and cross-sectional area 0.205 mm 2. The increase in resistance can be calculated to
R = (1.7×10-8 Ω m) (10 m) / ((0.205 mm2)(10-6 m2/mm2))
= 0.83 Ω
Convert between Electrical Resistivity Units
- 1 Ω m = 0.001 kΩ m = 102 Ω cm = 39.37 Ω inch = 3.28 Ω foot
Resistivity Compared to Copper
- Aluminum (pure): 1.6
- Brass: 3.7-4.9
- Cadmium: 4.4
- Chromium: 1.8
- Copper (hard-drawn): 1.03
- Copper (annealed): 1.00
- Gold: 1.4
- iron (pure): 5.68
- Lead: 12.8
- Nickel: 5.1
- Phosphor Bronze: 2.8-5.4
- Silver: 0.94
- Steel: 7.6-12.7
- Tin: 6.7
- Zinc: 3.4
• Electrical
Aluminum and Copper Wires - Electrical Resistance vs. Cross-Sectional Area
Electrical resistance in plain copper or aluminum wires.
Aluminum Conductor Characteristics
Characteristics of all-aluminum conductors (AAC).
Beams Natural Vibration Frequency
Estimate structures natural vibration frequency.
Electric Wire - Resistance
Electric resistance in wire made of Copper, Aluminum, Brass, Constantan, Nichrome, Platinum, Silver or Tungsten.
Electrical Conductivity - Elements and other Materials
Electric conductance is the ability of a element to conduct an electric current.
Electrical Motors - Maximum Cable Size and Length vs. Power
Maximum electrical motor cable length vs. power.
Electrical Parallel Circuits
Kirchhoff's Voltage and Current Laws
Kirchhoff's current and voltage laws.
Nickel-Chromium Heater Wire - Temperature Rise vs. Amps
Electric resistance vs. temperature rise for Nickel-Chromium electrical heater wire.
Resistivity and Conductivity - Temperature Coefficients Common Materials
Resistivity, conductivity and temperature coefficients for common materials like silver, gold, platinum, iron and more..
Voltage Dividers - Online Calculator
Output voltage potential divider.
