Aluminum Conductor Characteristics
All-aluminum conductor characteristics:
AWG | kcmil | Strands | Diameter (in) | GMR (ft) | Resistance (ohm/1000 ft) | Breaking Strength (lb) | Weight (lb/1000 ft) | ||
dc 20°C | 60 Hz ac 25°C | 60 Hz ac 50°C | |||||||
6 | 26.2 | 7 | 0.184 | 0.0056 | 0.659 | 0.673 | 0.739 | 563 | 24.6 |
4 | 41.7 | 7 | 0.232 | 0.007 | 0.414 | 0.423 | 0.465 | 881 | 39.1 |
2 | 66.4 | 7 | 0.292 | 0.0088 | 0.260 | 0.266 | 0.293 | 1350 | 62.2 |
1 | 83.7 | 7 | 0.328 | 0.0099 | 0.207 | 0.211 | 0.232 | 1640 | 78.4 |
1/0 | 106 | 7 | 0.368 | 0.0111 | 0.164 | 0.167 | 0.184 | 1990 | 98.9 |
2/0 | 133 | 7 | 0.414 | 0.0125 | 0.130 | 0.133 | 0.146 | 2510 | 125 |
3/0 | 168 | 7 | 0.464 | 0.014 | 0.103 | 0.105 | 0.116 | 3040 | 157 |
4/0 | 212 | 7 | 0.522 | 0.0158 | 0.0817 | 0.0835 | 0.0917 | 3830 | 198 |
250 | 7 | 0.567 | 0.0171 | 0.0691 | 0.0706 | 0.0777 | 4520 | 234 | |
250 | 19 | 0.574 | 0.0181 | 0.0693 | 0.0706 | 0.0777 | 4660 | 234 | |
267 | 7 | 0.586 | 0.0177 | 0.0647 | 0.0663 | 0.0727 | 4830 | 250 | |
267 | 19 | 0.593 | 0.0187 | 0.0648 | 0.0663 | 0.0727 | 4970 | 250 | |
300 | 19 | 0.629 | 0.0198 | 0.0575 | 0.0589 | 0.0648 | 5480 | 281 | |
336 | 19 | 0.666 | 0.021 | 0.0513 | 0.0527 | 0.0578 | 6150 | 316 | |
350 | 19 | 0.679 | 0.0214 | 0.0494 | 0.0506 | 0.0557 | 6390 | 328 | |
398 | 19 | 0.724 | 0.0228 | 0.0435 | 0.0445 | 0.0489 | 7110 | 373 | |
450 | 19 | 0.769 | 0.0243 | 0.0384 | 0.0394 | 0.0434 | 7890 | 422 | |
477 | 19 | 0.792 | 0.025 | 0.0363 | 0.0373 | 0.0409 | 8360 | 447 | |
477 | 37 | 0.795 | 0.0254 | 0.0363 | 0.0373 | 0.0409 | 8690 | 447 | |
500 | 19 | 0.811 | 0.0256 | 0.0346 | 0.0356 | 0.039 | 8760 | 469 | |
500 | 37 | 0.813 | 0.026 | 0.0346 | 0.0356 | 0.039 | 9110 | 468 | |
557 | 19 | 0.856 | 0.027 | 0.0311 | 0.032 | 0.0352 | 9750 | 521 | |
557 | 37 | 0.858 | 0.0275 | 0.0311 | 0.032 | 0.0352 | 9940 | 521 | |
600 | 37 | 0.891 | 0.0285 | 0.0288 | 0.0297 | 0.0326 | 10700 | 562 | |
636 | 37 | 0.918 | 0.0294 | 0.0272 | 0.0282 | 0.0309 | 11400 | 596 | |
650 | 37 | 0.928 | 0.0297 | 0.0266 | 0.0275 | 0.0301 | 11600 | 610 | |
700 | 37 | 0.963 | 0.0308 | 0.0247 | 0.0256 | 0.028 | 12500 | 656 | |
700 | 61 | 0.964 | 0.031 | 0.0247 | 0.0256 | 0.028 | 12900 | 656 | |
716 | 37 | 0.974 | 0.0312 | 0.0242 | 0.025 | 0.0275 | 12800 | 671 | |
716 | 61 | 0.975 | 0.0314 | 0.0242 | 0.0252 | 0.0275 | 13100 | 671 | |
750 | 37 | 0.997 | 0.0319 | 0.023 | 0.0251 | 0.0263 | 13100 | 703 | |
750 | 61 | 0.998 | 0.0321 | 0.023 | 0.0251 | 0.0263 | 13500 | 703 | |
795 | 37 | 1.03 | 0.0328 | 0.0217 | 0.0227 | 0.0248 | 13900 | 745 | |
795 | 61 | 1.03 | 0.0331 | 0.0217 | 0.0227 | 0.0248 | 14300 | 746 | |
875 | 37 | 1.08 | 0.0344 | 0.0198 | 0.0206 | 0.0227 | 15000 | 820 | |
875 | 61 | 1.08 | 0.0347 | 0.0198 | 0.0206 | 0.0227 | 15800 | 821 | |
900 | 37 | 1.09 | 0.0349 | 0.0192 | 0.0201 | 0.022 | 15400 | 844 | |
900 | 61 | 1.09 | 0.0352 | 0.0192 | 0.0201 | 0.022 | 15900 | 844 | |
954 | 37 | 1.12 | 0.036 | 0.0181 | 0.0191 | 0.0208 | 16400 | 895 | |
954 | 61 | 1.13 | 0.0362 | 0.0181 | 0.0191 | 0.0208 | 16900 | 895 | |
1000 | 37 | 1.15 | 0.0368 | 0.0173 | 0.0182 | 0.0199 | 17200 | 937 | |
1000 | 61 | 1.15 | 0.0371 | 0.0173 | 0.0182 | 0.0199 | 17700 | 937 |
- 1 ft = 0.3048 m
- 1 kcmil = 1000 cmil = 785.4×10-6 in2 = 0.5067 mm2
GMR - Geometric Mean Radius - quantifies a conductor’s internal inductance. By definition the GMR is the radius of an infinitely thin tube having the same internal inductance as the conductor out to a one-foot radius. GMR is often in feet to ease the calculations with distances measured in feet. Note that the GMR is less than the actual conductor radius.
• Electrical
AC - Active, Reactive and Apparent Power
Real, imaginary and apparent power in AC circuits.
Aluminum - Thermophysical Properties
Density, specific heat and thermal conductivity related to temperature.
Aluminum and Copper Wires - Electrical Resistance vs. Cross-Sectional Area
Electrical resistance in plain copper or aluminum wires.
Copper Wire - Electrical Resistance vs. Gauge
Gauge, weight, circular mils and electrical resistance in copper wire.
Electric Cable Size vs. Current Rating
Amps vs. cable size for fixed installations in buildings.
Electric Motors - 480 Volt Wiring
480V electrical motor wiring data - NEMA amps, starter size, HMCP size for motors ranging 1/2 to 500 hp.
Electric Wire - Resistance
Electric resistance in wire made of Copper, Aluminum, Brass, Constantan, Nichrome, Platinum, Silver or Tungsten.
Electrical Formulas
Commonly used electrical formulas like Ohms Law and more.
Electrical Resistance in Serial and Parallel Networks
Resistors in parallel and serial connections.
Electrical Resistance vs. Conductance
The reciprocal of electrical resistance is conductance.
Ohm's Law
The relation between voltage, current and electrical resistance.
Resistance vs. Resistivity
Electrical resistance and resistivity.
Single and Three Phase AC - Electric Current vs. Power
Convert between single phase (120, 240 and 480 Voltage) and three phase (240 and 480 Voltage).
Single Phase Power Equations
Power equations for single phased electrical systems.
Three-Phase Power - Equations
Electrical 3-phase equations.
