The power factor of an AC electric power system is defined as the ratio active (true or real) power to apparent power , where
- Active (Real or True) Power is measured in watts (W) and is the power drawn by the electrical resistance of a system doing useful work
- Apparent Power is measured in volt-amperes (VA) and is the voltage on an AC system multiplied by all the current that flows in it. It is the vector sum of the active and the reactive power
- Reactive Power is measured in volt-amperes reactive (VAR). Reactive Power is power stored in and discharged by inductive motors, transformers and solenoids
Reactive power is required for the magnetization of an electric motor but does not perform any work. Reactive power required by inductive loads increases the amounts of apparent power - and the required supply to the grid from the power supplier to the distribution system.
Increased reactive and apparent power will decrease the power factor - PF .
Power Factor
It is common to define the Power Factor - PF - as the cosine of the phase angle between voltage and current - or the " cosφ ":
PF = cos(φ) (1)
PF = power factor
φ = phase angle between voltage and current
The power factor defined by IEEE and IEC is the ratio between the applied active (true) power - and the apparent power , and can in general be expressed as:
PF = P / S (2)
PF = power factor
P = active (true or real) power (Watts)
S = apparent power (VA, volts amps)
A low power factor is the result of inductive loads such as transformers and electric motors. Unlike resistance loads creating heat by consuming kilowatts, inductive loads require a current flow to create magnetic fields to produce the desired work.
Power factor is an important measurement in electrical AC systems because
- an overall power factor less than 1 indicates that the electricity supplier need to provide more generating capacity than actually required
- the current waveform distortion that contributes to reduced power factor is caused by voltage waveform distortion and overheating in the neutral cables of three-phase systems
International standards such as IEC 61000-3-2 have been established to control current waveform distortion by introducing limits for the amplitude of current harmonics.
Example - Power Factor
A industrial plant draws 200 A at 400 V and the supply transformer and backup UPS is rated 400 V x 200 A = 80 kVA .
If the power factor - PF - of the loads is 0.7 - only
80 kVA × 0.7
= 56 kW
of real power is consumed by the system. If the power factor is close to 1 (a purely resistive circuit) the supply system with transformers, cables, switch-gear and UPS could be made considerably smaller.
- Any power factor less than 1 means that the circuit's wiring has to carry more current than what would be necessary with zero reactance in the circuit to deliver the same amount of (true) power to the resistive load.
Conductor Cross-Section vs. Power Factor
Required cross-section area of conductor with lower power factor:
| Power Factor | 1 | 0.9 | 0.8 | 0.7 | 0.6 | 0.5 | 0.4 | 0.3 |
| Cross-Section | 1 | 1.2 | 1.6 | 2.04 | 2.8 | 4.0 | 6.3 | 11.1 |
A low power factor is expensive and inefficient and some utility companies may charge additional fees when the power factor is less than 0.95. A low power factor will reduce the electrical system's distribution capacity by increasing the current flow and causing voltage drops.
"Leading" or "Lagging" Power Factors
A Power Factor is usually stated as "leading" or "lagging" to show the sign of the phase angle.
- With a purely resistive load the current and voltage changes polarity in step and the power factor will be 1 . Electrical energy flows in a single direction across the network in each cycle.
- Inductive loads - transformers, motors and wound coils - consumes reactive power with current waveform lagging the voltage.
- Capacitive loads - capacitor banks or buried cables - generates reactive power with current phase leading the voltage.
Inductive and capacitive loads stores energy in magnetic or electric fields in the devices during parts of the AC cycles. The energy is returned back to the power source during the rest of the cycles.
In systems with mainly inductive loads - typically industrial plants with many electric motors - the lagging voltage are compensated with capacitor banks.
Power Factor for a Three-Phase Motor
The total power required by an inductive device like a motor or similar consists of
- Active (true or real) power (measured in kilowatts, kW)
- Reactive power - the nonworking power caused by the magnetizing current, required to operate the device (measured in kilovars, kVAR)
The power factor for a three-phase electric motor can be expressed as:
PF = P / ((3)1/2 U I) (3)
PF = power factor
P = power applied (W, watts)
U = voltage (V)
I = current (A, amps)
- or alternatively:
P = (3)1/2 U I PF
= (3)1/2 U I cos(φ) (3b)
U, l and cos φ are normally quoted on the motor nameplate.
Typical Motor Power Factors
| Power (hp) | Speed (rpm) | Power Factor (cos φ ) | ||||
| Unloaded | 1/4 load | 1/2 load | 3/4 load | full load | ||
| 0 - 5 | 1800 | 0.15 - 0.20 | 0.5 - 0.6 | 0.72 | 0.82 | 0.84 |
| 5 - 20 | 1800 | 0.15 - 0.20 | 0.5 - 0.6 | 0.74 | 0.84 | 0.86 |
| 20 - 100 | 1800 | 0.15 - 0.20 | 0.5 - 0.6 | 0.79 | 0.86 | 0.89 |
| 100 - 300 | 1800 | 0.15 - 0.20 | 0.5 - 0.6 | 0.81 | 0.88 | 0.91 |
- 1 hp = 745.7 W
Power Factor by Industry
Typical un-improved power factors:
| Industry | Power Factor |
| Brewery | 75 - 80 |
| Cement | 75 - 80 |
| Chemical | 65 - 75 |
| Electro-chemical | 65 - 75 |
| Foundry | 75 - 80 |
| Forging | 70 - 80 |
| Hospital | 75 - 80 |
| Manufacturing, machines | 60 - 65 |
| Manufacturing, paint | 65 - 70 |
| Metalworking | 65 - 70 |
| Mine, coal | 65 - 80 |
| Office | 80 - 90 |
| Oil pumping | 40 - 60 |
| Plastic production | 75 - 80 |
| Stamping | 60 - 70 |
| Steel works | 65 - 80 |
| Textiles | 35 - 60 |
Benefits of Power Factor Corrections
- reduced power bills - avoiding low power factor penalty from the utility power company
- increased system capacity - additional loads can be added without overloading the system
- improved system operating characteristics by reduced line loss - due to less current
- improved system operating characteristics by gaining voltage - excessive voltage drops are avoided
Power Factor Correction with Capacitor
Power factor before improvement (cosΦ) | Capacitor correction factor | ||||||||||
| Power factor after improvement (cosΦ) | |||||||||||
| 1.0 | 0.99 | 0.98 | 0.97 | 0.96 | 0.95 | 0.94 | 0.93 | 0.92 | 0.91 | 0.90 | |
| 0.50 | 1.73 | 1.59 | 1.53 | 1.48 | 1.44 | 1.40 | 1.37 | 1.34 | 1.30 | 1.28 | 1.25 |
| 0.55 | 1.52 | 1.38 | 1.32 | 1.28 | 1.23 | 1.19 | 1.16 | 1.12 | 1.09 | 1.06 | 1.04 |
| 0.60 | 1.33 | 1.19 | 1.13 | 1.08 | 1.04 | 1.01 | 0.97 | 0.94 | 0.91 | 0.88 | 0.85 |
| 0.65 | 1.17 | 1.03 | 0.97 | 0.92 | 0.88 | 0.84 | 0.81 | 0.77 | 0.74 | 0.71 | 0.69 |
| 0.70 | 1.02 | 0.88 | 0.81 | 0.77 | 0.73 | 0.69 | 0.66 | 0.62 | 0.59 | 0.56 | 0.54 |
| 0.75 | 0.88 | 0.74 | 0.67 | 0.63 | 0.58 | 0.55 | 0.52 | 0.49 | 0.45 | 0.43 | 0.40 |
| 0.80 | 0.75 | 0.61 | 0.54 | 0.50 | 0.46 | 0.42 | 0.39 | 0.35 | 0.32 | 0.29 | 0.27 |
| 0.85 | 0.62 | 0.48 | 0.42 | 0.37 | 0.33 | 0.29 | 0.26 | 0.22 | 0.19 | 0.16 | 0.14 |
| 0.90 | 0.48 | 0.34 | 0.28 | 0.23 | 0.19 | 0.16 | 0.12 | 0.09 | 0.06 | 0.02 | |
| 0.91 | 0.45 | 0.31 | 0.25 | 0.21 | 0.16 | 0.13 | 0.09 | 0.06 | 0.02 | ||
| 0.92 | 0.43 | 0.28 | 0.22 | 0.18 | 0.13 | 0.10 | 0.06 | 0.03 | |||
| 0.93 | 0.40 | 0.25 | 0.19 | 0.15 | 0.10 | 0.07 | 0.03 | ||||
| 0.94 | 0.36 | 0.22 | 0.16 | 0.11 | 0.07 | 0.04 | |||||
| 0.95 | 0.33 | 0.18 | 0.12 | 0.08 | 0.04 | ||||||
| 0.96 | 0.29 | 0.15 | 0.09 | 0.04 | |||||||
| 0.97 | 0.25 | 0.11 | 0.05 | ||||||||
| 0.98 | 0.20 | 0.06 | |||||||||
| 0.99 | 0.14 | ||||||||||
Example - Improving power factor with capacitor
An electrical motor with power 150 kW has power factor before improvement cosΦ = 0.75 .
For a required power factor after improvement cosΦ = 0.96 - the capacitor correction factor is 0.58 .
The required KVAR capacity can be calculated as
C = (150 kW) 0.58
= 87 KVAR
Suggested Capacitor Ratings for T-Frame NEMA Class B Motors
Recommended sizes of KVAR units needed for correction of induction motors to approximately 95% power factor.
| Induction Motor Rating (HP) | Nominal Motor Speed (rpm) | |||||
| 3600 | 1800 | 1200 | ||||
| Capacitor Rating (KVAR) | Reduction of Line Current (%) | Capacitor Rating (KVAR) | Reduction of Line Current (%) | Capacitor Rating (KVAR) | Reduction of Line Current (%) | |
| 3 | 1.5 | 14 | 1.5 | 23 | 2.5 | 28 |
| 5 | 2 | 14 | 2.5 | 22 | 3 | 26 |
| 7.5 | 2.5 | 14 | 3 | 20 | 4 | 21 |
| 10 | 4 | 14 | 4 | 18 | 5 | 21 |
| 15 | 5 | 12 | 5 | 18 | 6 | 20 |
| 20 | 6 | 12 | 6 | 17 | 7.5 | 19 |
| 25 | 7.5 | 12 | 7.5 | 17 | 8 | 19 |
| 30 | 8 | 11 | 8 | 16 | 10 | 19 |
| 40 | 12 | 12 | 13 | 15 | 16 | 19 |
| 50 | 15 | 12 | 18 | 15 | 20 | 19 |
| 60 | 18 | 12 | 21 | 14 | 22.5 | 17 |
| 75 | 20 | 12 | 23 | 14 | 25 | 15 |
| 100 | 22.5 | 11 | 30 | 14 | 30 | 12 |
| 125 | 25 | 10 | 36 | 12 | 35 | 12 |
| 150 | 30 | 10 | 42 | 12 | 40 | 12 |
| 200 | 35 | 10 | 50 | 11 | 50 | 10 |
| 250 | 40 | 11 | 60 | 10 | 62.5 | 10 |
| 300 | 45 | 11 | 68 | 10 | 75 | 12 |
| 350 | 50 | 12 | 75 | 8 | 90 | 12 |
| 400 | 75 | 10 | 80 | 8 | 100 | 12 |
| 450 | 80 | 8 | 90 | 8 | 120 | 10 |
| 500 | 100 | 8 | 120 | 9 | 150 | 12 |
• Electrical
AC - Active, Reactive and Apparent Power
Real, imaginary and apparent power in AC circuits.
AC Circuits - Power vs. Voltage and Current
The alternating current In an AC circuit is generated by a sinusoidal voltage source.
Aluminum Conductor Characteristics
Characteristics of all-aluminum conductors (AAC).
Asynchronous Induction Motors - Electrical Properties
Typical electrical motor data like nominal current, fuse, start ampere, size of contactor and circuit breaker - for asynchronous induction motors.
Electric Motors - 480 Volt Wiring
480V electrical motor wiring data - NEMA amps, starter size, HMCP size for motors ranging 1/2 to 500 hp.
Electrical Induction Motors - Slip
Slip is the difference between an electrical induction motor's synchronous and asynchronous speed.
Electrical Motor Calculator: Power, Efficiency & Torque Calculations
Calculate amps, hp and kVA for electrical motors.
Electrical Motors - Frame Dimensions
Electrical motors NEMA frame dimensions.
Electrical Motors - Heat Loss
Heat loss from an electrical motor to the surroundings.
Electrical Motors - Insulation Classes
Electrical motors NEMA temperature and insulation classes.
Electrical Motors - Locked Rotor Design Code Letters
NEMA locked rotor indicating code letters for electrical motors.
Electrical Motors - Service Factors
Service factor - SF - is a measure of periodically overload capacity at which a motor can operate without beeing damaged.
Electrical Motors - Speed at Operating vs. Synchronous Load
Speed of an operating electrical motor with load is lower than the synchronous speed (no load) of the motor.
Electrical Motors - Speed vs. No. of Poles and Frequency
The speed of electrical motors with 2, 4, 6 or 8 poles at 50 Hz and 60 Hz.
Electrical Motors - Starting Devices
Direct-on-line starters, star-delta starters, frequency drives and soft starters.
Electrotechnical Abbreviations
Abbreviations according the International Electrotechnical Commission (IEC).
Heat Gain from Electrical Motors in Continuous Operation
Amount of heat transferred from electrical motor to ambient room vs. locations of fan and motor.
IEC Electric Motor Duty Cycles
The eight - S1 - S8 - IEC duty cycles of operating electrical motors.
Induction Motors - No. of Poles and Synchronous vs. Full Load Speed
Synchronous and full load speed of amplitude current (AC) induction motors.
Law of Cosines
One side of a triangle when the opposite angle and two sides are known.
Polyphase Motors - Voltage Imbalance vs. Derating Factor
Increased voltage imbalance and decreased efficiency.
Power
Single Phase Power Equations
Power equations for single phased electrical systems.
Three-Phase Electrical Motors - Power vs. Amps and Voltage
Full load amps, wire and conduit sizes for three phase electrical motors.
Three-Phase Power - Equations
Electrical 3-phase equations.
