Electrotechnical Abbreviations
Term | Abbreviation |
Ampere | A |
Ampere-hour | Ah |
Coulomb | C |
Farad | F |
Henry | H |
Joule | J |
kiloVolt | kV |
kiloVolt-Ampere | kVA |
kiloWatt | kW |
kiloWatthour | kWh |
MegaWatt | MW |
MegaOhm | MΩ |
microAmpere | μA |
microFarad | μF |
microWatt | μW |
milliAmpere | mA |
milliFarad | mF |
milliHenry | mH |
milliVolt | mV |
Ohm | Ω |
Volt | V |
Volt-Ampere | VA |
Volt-Coulomb | VC |
Watt | W |
Watthour | Wh |
• Electrical
Electrical Formulas
Commonly used electrical formulas like Ohms Law and more.
Electrical Motor Calculator: Power, Efficiency & Torque Calculations
Calculate amps, hp and kVA for electrical motors.
Electrical Units
Definition of common electrical units - like Ampere, Volt, Ohm, Siemens.
NEMA - National Electrical Manufacturers Association
National Electrical Manufacturers Association.
