Use Google Drive to make and share electric circuit drawings.
Log into your Google Account to save your own copy of this template. Share or publish your customized electric circuit drawing.
• 2D Schematic Drawings
Create and share online schematic P&ID, HVAC, Process Flow diagrams and drawings - using templates with Google Docs.
• Drawing Tools
2D and 3D engineering drawing tools.
• Electrical
• Process Control Systems
Instrumentation, design and documentation of process control systems.
12 Volt - Amps Amps vs. Wire Gauge: Choosing the Right Wire Size
Maximum current (amps) in a 12V electrical circuit vs. size (AWG) and length of wire.
AC - Active, Reactive and Apparent Power
Real, imaginary and apparent power in AC circuits.
Aluminum Conductor Characteristics
Characteristics of all-aluminum conductors (AAC).
Contract Types
Commonly used engineering and construction contracts.
Current Divider - Online Calculator
An electric current divider outputs a current that is a fraction of the input current.
Electric Circuits Voltage Drop
Ohm's law and voltage drop in electric circuits.
Electric Motors - 230 & 460V Three Phase Circuits Wiring
Sizing of copper wire and transformers for three phase 230 & 460V electrical motors.
Electric Wire - Resistance
Electric resistance in wire made of Copper, Aluminum, Brass, Constantan, Nichrome, Platinum, Silver or Tungsten.
Electrical Formulas
Commonly used electrical formulas like Ohms Law and more.
Electrical Motor Calculator: Power, Efficiency & Torque Calculations
Calculate amps, hp and kVA for electrical motors.
Electrical Motors - Single Phase 230 V Circuit Wiring
Copper wire gage and transformer size for single phase 230 volts electrical motors.
Electrical Parallel Circuits
Electrical Resistance in Serial and Parallel Networks
Resistors in parallel and serial connections.
Electrical Series Circuits
Voltage and current in electrical series circuits.
Electrical Units
Definition of common electrical units - like Ampere, Volt, Ohm, Siemens.
Electrotechnical Abbreviations
Abbreviations according the International Electrotechnical Commission (IEC).
Greek Alphabet
The Greek alphabet is essential expressing formulas and in technical language.
Kirchhoff's Voltage and Current Laws
Kirchhoff's current and voltage laws.
Ohm's Law
The relation between voltage, current and electrical resistance.
Draw P&ID diagrams online in the browser with Google Docs.
PFD - Process Flow Diagram - Online Drawing Tool
Draw Process Flow Diagrams with this online Google Docs drawing application.
Relative vs. Absolute Voltage
Electric circuits and voltage at any point.
Transformers - kVA Ratings vs. Volt and Amps
Alternating voltage and induced electro magnetic field - e.m.f. - in a transformer.
Voltage Sources vs. Current Sources
Voltage and Current Sources
