Relative vs. Absolute Voltage
Absolute Voltage
If voltage at point A is quoted with reference to the earth point - the absolute potential - then the voltage is written UA.
Relative Voltage
If voltage at point A is quoted with reference to point B - then the voltage is written UAB.
Example - Relative and Absolute Voltage
The total resistance in the series circuit above can be calculated
R = (33 ohm) + (47 ohm) + (33 ohm)
   = 113 ohm
The current in the circuit can be calculated
I = (12 volts) / (113 ohm)
  = 0.11 ampere
The relative voltage between point A and BVAB - can be calculated
UAB = (33 ohm) (0.11 ampere)
      = 3.6 volts
The absolute voltage in point A relative to earth is
UA = 12 V
The absolute voltage in point B relative to earth is
UB = UA - UAB
    = (12 volt) - (3.6 volt)
    = 8.4 volt
Electrical
Electrical units, amps and electrical wiring, wire gauge and AWG, electrical formulas and motors.
Current Divider - Online Calculator
An electric current divider outputs a current that is a fraction of the input current.
Electric Circuits Voltage Drop
Ohm's law and voltage drop in electric circuits.
Electrical Formulas
Commonly used electrical formulas like Ohms Law and more.
Electrical Series Circuits
Voltage and current in electrical series circuits.
Kirchhoff's Voltage and Current Laws
Kirchhoff's current and voltage laws.
