Current Divider - Online Calculator
A current divider is a linear circuit that produces an output current that is a fraction of the input current.
Current is split between the branches of the divider. The total resistance in the electrical circuit can calculated
R T = R 1 R 2 / (R 1 + R 2 )      (1)
R T = total resistance (ohms, Ω)
R n = resistance in branch n (ohms, Ω )
The voltage difference across the circuit
U = I R T
= I R 1 R 2 / (R 1 + R 2 )   (2)
U = electrical potential (volts, V)
I = total current through the circuit (amps, A)
Split current I 1 can be calculated
I 1 = U / R 1
= (I R 1 R 2 / (R 1 + R 2 ) ) / R 1
=   I R 2 / (R 1 + R 2 )     (3)
Split current I 2 can be calculated
I 2 = U / R 2
= (I R 1 R 2 / (R 1 + R 2 ) ) / R 2
=   I R 1 / (R 1 + R 2 )     (4)
Example - Current Divider
The total resistance in a current divider with supply voltage 3.3 V and resistor R 1 = 220 ohm and resistor R 2 =  47 ohm can be calculated as
R T = ( 220 ohm ) ( 47 ohm ) / (( 220 ohm ) + ( 47 ohm ))
= 38.7 ohm
The total current through the current divider can be calculated
I = (3.3 V) / (38.7 ohm)
= 0.085 amps
= 85 mA
The current through resistor R 1 can be calculated
I 1 = (3.3 V) / (220 ohm)
= 0.015 amps
= 15 mA
The current through resistor R 2 can be calculated
I 2 = (3.3 V) / (47 ohm)
= 0.070 amps
= 70 mA
R - total resistance (ohms)
I 1 - split current (amps)
I 2 - split current (amps)
I - total current (amps)
Electrical
Electrical units, amps and electrical wiring, wire gauge and AWG, electrical formulas and motors.
Electrical Parallel Circuits
Electrical Resistance in Serial and Parallel Networks
Resistors in parallel and serial connections.
Electrical Series Circuits
Voltage and current in electrical series circuits.
Kirchhoff's Voltage and Current Laws
Kirchhoff's current and voltage laws.
Potential Divider - Online Calculator
Output voltage with a potential divider.
Relative vs. Absolute Voltage
Electric circuits and voltage at any point.
