Electrical Motor Calculator: Power, Efficiency & Torque Calculations
The calculators below can be used to calculate electric motor amps, horsepower and 3-phase kVa.
Calculate Current (amps)
Calculate Power (horsepower)
Calculate 3 Phase Apparent Power (kVA)
  • RLA - "Running Load Amps" - current drawn during normal operation of electric motor.
  • FLA - "Full Load Amps" - amount of current drawn when full-load torque and horsepower is reached for the motor. FLA is usually determined in laboratory tests. Note! - in the calculator above FLA is RLA + 25% .
  • 1 hp = 0.745 kW
Electrical
AC - Active, Reactive and Apparent Power
Real, imaginary and apparent power in AC circuits.
Asynchronous Induction Motors - Electrical Properties
Typical electrical motor data like nominal current, fuse, start ampere, size of contactor and circuit breaker - for asynchronous induction motors.
Electric Motors - 480 Volt Wiring
480V electrical motor wiring data - NEMA amps, starter size, HMCP size for motors ranging 1/2 to 500 hp.
Electric Motors - Efficiency
Electrical Motors - Frame Dimensions
Electrical motors NEMA frame dimensions.
Electrical Motors - Horsepower vs. Voltage and Amps
Electrical motors horsepower rating vs. their ampere rating.
Electrical Motors - Insulation Classes
Electrical motors NEMA temperature and insulation classes.
Electrical Motors - Locked Rotor Design Code Letters
NEMA locked rotor indicating code letters for electrical motors.
Electrical Vehicle Charging - Power vs. Voltage and Amps
EV Charging - AC vs. DC, single phase vs. three phase and power vs. voltage and amps.
Electrotechnical Abbreviations
Abbreviations according the International Electrotechnical Commission (IEC).
Heat Gain from Electrical Motors in Continuous Operation
Amount of heat transferred from electrical motor to ambient room vs. locations of fan and motor.
NEMA - National Electrical Manufacturers Association
National Electrical Manufacturers Association.
Polyphase Motors - Voltage Imbalance vs. Derating Factor
Increased voltage imbalance and decreased efficiency.
Single Phase Power Equations
Power equations for single phased electrical systems.
