Electrical Motors - Insulation Classes
Electrical insulation systems are rated by standard NEMA (National Electrical Manufacturers Association) classifications according to maximum allowable operating temperature. Electrical motors will rapidly degrade if the internal temperatures exceeds the insulation temperature limits.
Insulation Class | Temperature Limit (oC) |
A1) | 105 |
B1) | 130 |
F2) | 155 |
H2) | 180 |
1) Hygroscopic insulation - avoided for open and outdoor locations - shortened lifetime if condensation in the insulation occurs
2) Non-hygroscopic insulation - preferred for open and outdoor locations, higher ambient temperatures ..
• Electrical
Electric Motors - Efficiency
Electrical Induction Motors - Synchronous Speed
Operating speed of an induction motor depends on the input power frequency and the number of magnetic poles in the motor.
Electrical Motor Calculator: Power, Efficiency & Torque Calculations
Calculate amps, hp and kVA for electrical motors.
Electrical Motors - Full Load Amps
Full load amps for single and 3-phase 460 volts, 230 volts and 115 volts electric motors.
Electrical Motors - Shaft Power vs. Voltage and Current
Calculate electric motors shaft power.
