Electrical Induction Motors - Synchronous Speed
The synchronous speed for an electric induction motor is determined by
  • the power supply frequency, and
  • the number of poles in the motor winding.
The synchronous speed can be calculated as:
n = f (2 / p) 60                      (1)
n = shaft rotation speed (rev/min, rpm)
f = frequency of electrical power supply (Hz, cycles/sec, 1/s)
p = number of poles
Note - an induction motor will never reach its synchronous speed. If it did - the rotor would appear to be stationary to the rotating stator field since it would rotate with the same speed. With no relative motion between stator and rotor field no voltage will be induced in the motor. The speed of an induction motor is therefore limited to a speed below synchronous speed and the difference between synchronous speed and actual speed is called slip.
Example - Synchronous Speed of Electric Motor with Two Poles
A motor with two poles is supplied with power with frequency 50 Hz (1/s). The rotation speed can be calculated as
n =  (50 1/s) (2 / 2) (60 s/min)
   = 3000 rpm (1/min)
Synchronous rotation speed at different frequencies and number of poles
Shaft rotation - n - (rev/min, rpm)
Frequency
- f -
(Hz)
Number of poles - p -
24681012
10 600 300 200 150 120 100
20 1200 600 400 300 240 200
30 1800 900 600 450 360 300
40 2400 1200 800 600 480 400
501) 3000 1500 1000 750 600 500
602) 3600 1800 1200 900 720 600
70 4200 2100 1400 1050 840 700
80 4800 2400 1600 1200 960 800
90 5400 2700 1800 1350 1080 900
100 6000 3000 2000 1500 1200 1000
  1. Motors designed for 50 Hz are most common outside U.S
  2. Motors designed for 60 Hz are most common in U.S
Variable Frequency Drive
A variable frequency drive modulates the speed of an electrical motor by changing the frequency of the power supply.
Electrical
Electric Motors - Efficiency
Electrical Induction Motors - Slip
Slip is the difference between an electrical induction motor's synchronous and asynchronous speed.
Electrical Induction Motors - Torque vs. Speed
Full load operating torque vs. break down, pull up and locked rotor torque.
Electrical Motors - Frame Dimensions
Electrical motors NEMA frame dimensions.
Electrical Motors - Horsepower vs. Voltage and Amps
Electrical motors horsepower rating vs. their ampere rating.
Electrical Motors - Insulation Classes
Electrical motors NEMA temperature and insulation classes.
Electrical Motors - Shaft Power vs. Voltage and Current
Calculate electric motors shaft power.
Electrical Motors - Speed at Operating vs. Synchronous Load
Speed of an operating electrical motor with load is lower than the synchronous speed (no load) of the motor.
Induction Motors - No. of Poles and Synchronous vs. Full Load Speed
Synchronous and full load speed of amplitude current (AC) induction motors.
Three-Phase Electrical Motors - Power vs. Amps and Voltage
Full load amps, wire and conduit sizes for three phase electrical motors.
