Electrical Motors - Horsepower vs. Voltage and Amps
Horsepower rating compared to electric motor ampere rating - 115 VAC and 230 VAC - are indicated below:
Electrical Motors - Horsepower, Voltage, Efficiency and Amps
Ampere Rating (amps)
Power Rating
(hp)
115 VAC230 VAC
Efficiency (%)
50705070
1/4 3.2 2.3 1.6 1.2
1/3 4.3 3.1 2.2 1.5
1/2 6.5 4.6 3.2 2.3
3/4 9.7 7.0 4.9 3.5
1 13.0 9.3 6.5 4.6
1 1/2 19.5 13.9 9.7 7.0
2 25.9 18.5 13.0 9.3
5 64.9 46.3 32.4 23.2
  • 1 hp = 745.7 W
Note that an electric motor is an inductive load. With low power factor it pulls lot of amps producing little hp output.
Electrical
Electric Motors - Efficiency
Electrical Induction Motors - Synchronous Speed
Operating speed of an induction motor depends on the input power frequency and the number of magnetic poles in the motor.
Electrical Induction Motors - Torque vs. Speed
Full load operating torque vs. break down, pull up and locked rotor torque.
Electrical Motor Calculator: Power, Efficiency & Torque Calculations
Calculate amps, hp and kVA for electrical motors.
Electrical Motors - Shaft Power vs. Voltage and Current
Calculate electric motors shaft power.
