Electrical Motors - Shaft Power vs. Voltage and Current
Power is in general rated in watt (W) or horsepower (hp) . The old imperial unit horsepower is equal to 746 watts (0.745 kW) or 33000 lb ft per minute (or 550 lb ft per second).
The unit of electric power - 1 watt - is equal to the power produced by an electrical current of 1 amp at a potential difference of 1 volt .
- 1 watt = 1 / 746 hp
- 1 hp = 746 watts = 0.76 kW
Shaft Power in watts
Direct Current - DC
Shaft power produced from a direct current (DC) electrical motor:
Pshaft_kW = ηm U I / 1000 (1)
Pshaft_kW = shaft power (kW)
ηm = motor efficiency
U = voltage (V)
I = current (A, amps)
Alternating Current - AC
Shaft power produced from an alternating current (AC) electrical motor:
Single Phase
Pshaft_kW = ηm U I PF / 1000 (1b)
PF = Power Factor
Two Phase Four Wire
Pshaft_kW = ηm 2 U I PF / 1000 (1c)
Three Phase
Pshaft_kW = ηm 1.73 U I PF / 1000 (1d)
Shaft Power in hp
Shaft power as horse power :
Pshaft_hp = Pshaft_kW / 0.746 (2)
or for a DC motor
Pshaft_hp = (ηm U I / 1000) / 0.746
= ηm U I / 746 (2b)
Pshaft_hp = shaft power (hp)
Example - Shaft Power Electric Motor
The shaft power produced by an electric direct current motor with 36 V, 85% efficiency and 5 amps - can be calculated in watts as
Pshaft_kW = 0.85 (36 V) (5 amps) / 1000
= 0.153 kW
= 153 W
The shaft power as hp
Pshaft_hp = (0.153 kW) / 0.746
= 0.21 hp
Standard Horsepower Ratings
Standard horsepower ratings for electrical motors - 1 to 4000 hp are indicated below:
- 1, 1.5, 2, 3, 5, 7.5, 10, 15, 20, 25, 30, 40, 50, 60, 75, 100, 125, 150, 200, 250, 300, 350, 400, 450, 500, 600, 700, 800, 900, 1000, 1250, 1500, 1750, 2000, 2250, 2500, 3000, 3500, 4000
Nominal voltage of not more than 600 V AC and nominal frequency 50 or 60 Hz .
• Electrical
Asynchronous Induction Motors - Electrical Properties
Typical electrical motor data like nominal current, fuse, start ampere, size of contactor and circuit breaker - for asynchronous induction motors.
Electric Motors - 480 Volt Wiring
480V electrical motor wiring data - NEMA amps, starter size, HMCP size for motors ranging 1/2 to 500 hp.
Electrical Induction Motors - Synchronous Speed
Operating speed of an induction motor depends on the input power frequency and the number of magnetic poles in the motor.
Electrical Motors - Frame Dimensions
Electrical motors NEMA frame dimensions.
Electrical Motors - Horsepower vs. Voltage and Amps
Electrical motors horsepower rating vs. their ampere rating.
Electrical Motors - Insulation Classes
Electrical motors NEMA temperature and insulation classes.
Electrical Motors - Locked Rotor Design Code Letters
NEMA locked rotor indicating code letters for electrical motors.
Electrical Motors - Starting Devices
Direct-on-line starters, star-delta starters, frequency drives and soft starters.
Electrical Vehicle Charging - Power vs. Voltage and Amps
EV Charging - AC vs. DC, single phase vs. three phase and power vs. voltage and amps.
Fan Motors - Starting Torques
The motor must be capable of accelerating the fan wheel to it's operating speed.
Heat Gain from Electrical Motors in Continuous Operation
Amount of heat transferred from electrical motor to ambient room vs. locations of fan and motor.
Measurement of Electrical Power
Measure electric power with an ammeter and a voltmeter.
Nema Starters
Nema sized contactors or starters.
Power
Single Phase Power Equations
Power equations for single phased electrical systems.
Three-Phase Power - Equations
Electrical 3-phase equations.
