Hydraulic Pump Power
The ideal hydraulic power to drive a pump depends on
- the mass flow rate the
- liquid density
- the differential height
- either it is the static lift from one height to an other or the total head loss component of the system - and can be calculated like
Ph(kW) = q ρ g h / 3.6×106
= q p / 3.6×106 (1)
Ph(kW) = hydraulic power (kW)
q = flow (m3/h)
ρ = density of fluid (kg/m3)
h = differential head (m)
p = differential pressure (N/m2, Pa)
The hydraulic Horse Power can be calculated as:
Ph(hp) = Ph(kW) / 0.746 (2)
Ph(hp) = hydraulic horsepower (hp)
Or - alternatively
Ph(hp) = qgpm hft SG / (3960 η) (2b)
qgpm = flow (gpm)
hft = differential head (ft)
SG = Specific Gravity (1 for water)
η = pump efficiency (0..1)
Example - Power pumping Water, SI Units
1 m3/h of water is pumped a head of 10 m. The theoretical pump power can be calculated as
Ph(kW) = (1 m3/h) (1000 kg/m3) (9.81 m/s2) (10 m) / (3.6×106)
= 0.027 kW
Example - Power pumping Water, Imperial Units
600 gpm of water is pumped a head of 110 ft. The efficiency ofthe pump i s 60% (0.6) and the specific gravity of water is 1. The pump shaft power can be calculated as
Ph(kW) = (600 gpm) (110 ft) (1) / ((3960) (0.6))
= 27.8 hp
Shaft Pump Power
The shaft power - the power required transferred from the motor to the shaft of the pump - depends on the efficiency of the pump and can be calculated as
Ps(kW) = Ph(kW) / η (3)
Ps(kW) = shaft power (kW)
Online Pump Calculator - SI-units
The calculator below can used to calculate the hydraulic and shaft power of a pump:
Online Pump Calculator - Imperial units
The calculator below can used to calculate the hydraulic and shaft power of a pump using Imperial units:
- Specific weight of water is 62.4 lb/ft3
- Check the relation between Density, Specific Weight and Specific Gravity
- Make Shortcut to this Calculator on Your Home Screen?
• Pumps
Centrifugal Pumps
Centrifugal Pumps - Influence of Viscosity
Hydrodynamic losses through pumps depends on fluid viscosities.
Centrifugal Pumps - Shut-Off Head
Centrifugal pumps and maximum shut-off head.
Efficiency in Pumps or Fans
The overall pump and fan efficiency is the ratio power gained by the fluid to the shaft power supplied.
Electrical Motors - Shaft Power vs. Voltage and Current
Calculate electric motors shaft power.
Required power to pump water.
Hydraulic Pump Motor Sizing
Motor size vs. flow rate, shaft torque, shaft power and hydraulic power.
Positive Displacement Pumps
Introduction tutorial to positive displacement pumps basic operating principles.
Power
Power Gained by Fluid from Pump or Fan
Calculate the power gained by fluid from an operating pump or fan.
Pump - Temperature Rise vs. Volume Flow
Calculate temperature rise vs. volume flow in pumps.
Pumping Water - Energy Cost Calculator
Calculate the energy cost of pumping water.
System Curve and Pump Performance Curve
Utilize the system curve and the pump performance curve to select the proper pump for a particular application.
Calculate specific work done by pumps, fans, compressors or turbines.
Work done by Force
Work done by a force acting on an object.
