Efficiency in Pumps or Fans
For a fluid flow process involving a pump or fan the overall efficiency is related to the
- hydraulic
- mechanical
- volumetric
losses in the pump or fan.
Hydraulic Loss and Hydraulic Efficiency
Hydraulic losses relates to the construction of the pump or fan and is caused by the friction between the fluid and the walls, the acceleration and retardation of the fluid and the change of the fluid flow direction.
The hydraulic efficiency can be expressed as:
ηh = w / (w + wl) (1)
ηh = hydraulic efficiency
w = specific work from the pump or fan (J/kg)
wl = specific work lost due to hydraulic effects (J/kg)
Mechanical Loss and Mechanical Efficiency
Mechanical components - like transmission gear and bearings - creates mechanical losses that reduces the power transferred from the motor shaft to the pump or fan impeller.
The mechanical efficiency can be expressed as:
ηm = (P - Pl) / P (2)
ηm = mechanical efficiency
P = power transferred from the motor to the shaft (W)
Pl = power lost in the transmission (W)
Volumetric Loss and Volumetric Efficiency
Due to leakage of fluid between the back surface of the impeller hub plate and the casing, or through other pump components - there is a volumetric loss reducing the pump efficiency.
The volumetric efficiency can be expressed as:
ηv = q / (q + ql) (3)
ηv = volumetric efficiency
q = volume flow out of the pump or fan (m3/s)
ql = leakage volume flow (m3/s)
Total Loss and Overall Efficiency
The overall efficiency is the ratio of power actually gained by the fluid to power supplied to the shaft. The overall efficiency can be expressed as:
η = ηh ηm ηv (4)
η = overall efficiency
The losses in a pump or fan converts to heat that is transferred to the fluid and the surroundings. As a rule of thumb - the temperature increase in a fan transporting air is approximately 1 oC.
Example - Hydraulic Efficiency for a Pump
An inline water pump works between pressure 1 bar (1×105 N/m2) and 10 bar (10×105 N/m2). The density of water is 1000 kg/m3. The hydraulic efficiency is ηh = 0.91.
The actual water head (water column) can be calculated as:
h = (p2 - p1) / γ
= (p2 - p1) / (ρ g)
= ((10×105 N/m2) - (1×105 N/m2)) / ((1,000 kg/m3) (9.81 m/s2))
= 91.7 m - water column
The pump must be constructed for the specific work:
wc = g h / ηh
= (9.81 m/s2) (91.7 m) / 0.91
= 988.6 (J/kg, m2/s2)
The construction or design head is:
h =wc / g
= (988.6 m2/s2) / (9.81 m/s2)
= 100.8 m - water column
• Pumps
Centrifugal Pumps - Influence of Viscosity
Hydrodynamic losses through pumps depends on fluid viscosities.
Efficiency
The measure of usefulness.
Power Gained by Fluid from Pump or Fan
Calculate the power gained by fluid from an operating pump or fan.
Pumping Water - Required Horsepower
Horsepower required to pump water.
Pumps - Specific Speed
Characterizing of impeller types in pumps in a unique and coherent manner.
Static Pressure vs. Head
System Curve and Pump Performance Curve
Utilize the system curve and the pump performance curve to select the proper pump for a particular application.
Calculate specific work done by pumps, fans, compressors or turbines.
