Specific work is work per unit weight. Specific work in turbo machines as fans, pumps, compressors or turbines has the SI-units
  • Nm/kg = J/kg = m2/s2
Specific Work of a Pump or Fan
Specific work of a pump or fan working with an incompressible fluid can be expressed as:
w = (p2 - p1) / ρ                                  (1)
w = specific work (Nm/kg, J/kg, m2/s2)
p = pressure (N/m2)
ρ = density (kg/m3)
Specific Work of a Turbine
Specific work of a turbine with an incompressible fluid can be expressed as:
w = (p1 - p2) / ρ                                     (2)
Specific Work of a Compressor
A compressor works with compressible fluids and the specific work for an isentropic compressor process can be expressed with the help of
p1 v1κ = p2 v2κ                                        (3)
v= volume (m3)
κ = cp / cv   - ratio of specific heats (J/kg K)
Specific work:
w = κ / (κ -1) R T1 (( p2 / p1)((κ-1) / κ) - 1)                                    (4)
R= individual gas constant (J/kg K)
T= absolute temperature (K)
Specific Work of a Gas Turbine
A gas turbine expands a compressible fluid and the specific work can be expressed as
w = κ / (κ -1) R T1 (1 - ( p2 / p1)((κ-1) / κ))                                    (5)
Head in Turbomachines
The specific work can on basis of the energy equation be expressed with the head as:
w = g h                                        (6)
h= head (m)
g= acceleration of gravity (m/s2)
Transformed to express head:
h = w / g                                        (7)
Example - Specific Work of a Water Pump
A water pump works between 1 bar (105 N/m2) and 10 bar (10×105 N/m2). The specific work can be calculated with (1):
w = (p2 - p1) / ρ
    =((10×105 N/m2) - (105 N/m2)) / (1000 kg/m3)
    = 900 Nm/kg
Dividing by acceleration of gravity the head can be calculated using (7):
hwater= (900 Nm/kg) / (9.81 kg/s2)
    = 91.74 (m) water column
Example - Specific Work of an Air Compressor
An air compressor works with air at 20 oC compressing the air from 1 bar absolute (105 N/m2) to 10 bar (10×105 N/m2). The specific work can be expressed with (4):
    = ((1.4 J/kg K) / ((1.4 J/kg K) - 1)) (286.9 J/kg K) ((273 K) + (20 K)) (((10×105 N/m2) / (105 N/m2))(((1.4 J/kg K) - 1)/(1.4 J/kg.K)) - 1 )
    = 273826 Nm/kg
κair= 1.4 (J/kg K) - ratio of specific heat air
Rair= 286.9 (J/kg K) - individual gas constant air
hair= (274200 Nm/kg) / (9.81 kg/s2)
    = 27951 (m) air column
Fluid Mechanics
Pumps
Air - SCFM versus ACFM and ICFM
Actual air compressor capacity (ACFM) vs. standard air capacity (SCFM) and inlet air capacity (ICFM).
Efficiency in Pumps or Fans
The overall pump and fan efficiency is the ratio power gained by the fluid to the shaft power supplied.
Required power to pump water.
Isentropic Flow
Fluid flow with constant entropy is also called isentropic flow.
Pumps - Specific Speed
Characterizing of impeller types in pumps in a unique and coherent manner.
Pumps vs. Compressors, Blowers and Fans
The difference between pumps, compressors, blowers and fans.
Types of Air Compressors
Reciprocating, rotary screw and rotary centrifugal air compressors.
Work done by Force
Work done by a force acting on an object.
