The actual CFM of a compressor operating at "non-standard" conditions like
can be calculated as
ACFM = (100 SCFM) [(14.7 psia) / ((12.23 psia) - (0.5069 psia) (80 / 100))]((540 o R ) / (520 o R))
= 129.1
Inlet Cubic Feet per Minute - ICFM - is used by compressor vendors to establish conditions in front of additional equipment like inlet filter, blower or booster.
When air passes through the filter there will be a pressure drop. The conversion from ACFM to ICFM can be expressed as
ICFM = ACFM (P act / P f ) (T f / T act ) (2)
ICFM = Inlet Cubic Feet per Minute
P f = Pressure after filter or inlet equipment (psia)
T f = Temperature after filter or inlet equipment ( o R)
The Ideal Gas Law is accurate only at relatively low pressures and high temperatures. To account for the deviation from the ideal situation, another factor is included. It is called the Gas Compressibility Factor, or Z-factor . This correction factor depends on the pressure and temperature for each gas considered.
The True Gas Law, or the Non-Ideal Gas Law, becomes:
P V = Z n R T (3)
Z = Gas Compressibility Factor
n = number of moles of gas present
Air volume conversion factors related to air with temperature 70°F (21.1°C) :
Air Temperature | Factor | |
°F | °C | |
0 | -17.2 | 1.152 |
10 | -12.2 | 1.128 |
20 | -6.7 | 1.104 |
30 | -1.1 | 1.082 |
40 | 4.4 | 1.060 |
50 | 10.0 | 1.039 |
60 | 15.6 | 1.019 |
70 | 21.1 | 1.000 |
80 | 26.7 | 0.981 |
90 | 32.2 | 0.964 |
100 | 37.8 | 0.946 |
110 | 43.3 | 0.930 |
120 | 48.9 | 0.914 |
130 | 54.4 | 0.898 |
140 | 60.0 | 0.883 |
150 | 65.6 | 0.869 |
160 | 71.1 | 0.855 |
170 | 76.7 | 0.841 |
Yearly power cost for operating an air compressor.
Inlet pipe size and maximum air flow.
Air consumption of air tools.
Elevation above sea level - in feet and meter - with barometric and atmospheric pressure - inches mercury, psia, kg/cm2 and kPa.
Relative humidity in moist air is the ratio of partial vapor pressure to air pressure.
Common rating terms for air flow capacity are ICFM, FAD, ANR, SCFM or nl/min.
Calculate specific work done by pumps, fans, compressors or turbines.
Reciprocating, rotary screw and rotary centrifugal air compressors.
Calculate pressure drops in vacuum pipe lines.
