Air Compressors - Maximum Air Flow vs. Inlet Pipe Size
The pressure loss through an air compressor inlet should be kept to a minimum to avoid noise problems. The diagram below indicates reasonable maximum flow through an inlet pipe.
- 1 cfm = 0.47 l/s
- 1 inch = 25.4 mm
• Gases and Compressed Air
Air - SCFM versus ACFM and ICFM
Actual air compressor capacity (ACFM) vs. standard air capacity (SCFM) and inlet air capacity (ICFM).
Compressed Air Receivers
Calculating air receivers capacity.
Rating of Air Compressors and Air Equipment
Common rating terms for air flow capacity are ICFM, FAD, ANR, SCFM or nl/min.
Single Acting Pneumatic Piston - Air Consumption
Calculate air volume used by a single-acting piston.
Types of Air Compressors
Reciprocating, rotary screw and rotary centrifugal air compressors.
